Trouble with AJA Kona HDMI Card
apla1297
Post by apla1297 »
Has anyone else tried the AJA Kona HDMI card? The one linked below to be exact.
https://www.aja.com/products/kona-hdmi
I just installed one and while it seems to be working great in the AJA control panel it is not showing up at all in Resolume. I am using Res 6.1.1. Any and all help would be appreciated.
Some side notes
- I made sure all other AJA software was closed before opening Resolume.
- I am on the latest AJA firmware.
- There is also an AJA SDI capture card in the machine that shows up just fine is Resolume.
- This is a windows 10 build.
Vjcheshire
Re: Trouble with AJA Kona HDMI Card
Post by Vjcheshire »
I just got a new machine up and running with this card and I cannot see it in the sources for Resolume...
Resolume 6.1.2 with windows 10. Same issue, shows in aja with a capture, doesn't show in Res.
Looks like this is a fairly new card, and not supported in Resolume yet.
We'll look into it.
Vjcheshire
Bump. Hoping to get support for this card eventually. If not is there any similar card to this that does have support?
Vjcheshire wrote: Thu Mar 28, 2019 21:33 Bump. Hoping to get support for this card eventually.
We're working on it.
Vjcheshire wrote: Thu Mar 28, 2019 21:33 If not is there any similar card to this that does have support?
The Decklink quad HDMI should offer the same inputs and should work with Resolume: https://www.blackmagicdesign.com/produc ... s/W-DLK-36
Vjcheshire
Thanks for the update. Just debating on whether to return this card or not and snag another one. I primarily deal with HDMI inputs and this one seemed to be the best for its price and availability.
Unfortunately the BM card is on pre-order. May just order a hardware mixer for upcoming shows and go the USB capture with 1 4k input for now.
DanielTan
Post by DanielTan »
Zoltán wrote: Fri Mar 29, 2019 13:41
Is Arena 7 already support AJA Kona 4 HDMI?
Any issue with Blackmagic Decklink Quad HDMI?
Which card do you prefer?
Christoph
Post by Christoph »
DanielTan wrote: Sun Mar 08, 2020 13:47 Hi,
The DeckLink Quad HDMI Recorder should work with Resolume the same way as the other DeckLink-cards!
zone_nord
Post by zone_nord »
hello,
is AJA KONA HDMI (https://www.aja.com/products/kona-hdmi) supported now in arena 7?
thank you
Yes, it should work since 7.2
https://www.aja.com/compatibility/kona
