Can I save a composition to a Clip?
greenvillehughes
Post by greenvillehughes » Tue Dec 04, 2018 12:47
I searched the forum but did not find any help on this topic...
I'm using Arena 6. I would like to save a composition to a clip.
Specifically, I have a video clips on layers 1 and 2 and animated text on layer 3 with the mask mode set to ALL BELOW.
I would like to save this to a clip so I can put it on a separate layer where I'm using autopilot to transition a series of clips.
So that's the goal. Please let me know where I can get information on how to save a composition to a clip in Arena 6.
Thank you!
He2neg
Re: Can I save a composition to a Clip?
Post by He2neg » Tue Dec 04, 2018 13:20
You can record your output to a clip... u will find a rec button under your layers on the right side of the interface...
This recorded clip will automatic apear on the first free clip on the first layer.
its not decoded into dxv so when you have the time you can decode the clip after you recorded it.
in the settings you can find the location were the clip is stored on your system.
https://resolume.com/support/en/recording
Laptop: XMG P507 // Intel i7-5500 / GTX-1060 / 1tb SSD / 32gb RAM // Touch OSC / Lemur/ APC-40
~self employed AV technician / Schu.VT@posteo.de~
~Berlin~
greenvillehughes
Post by greenvillehughes » Tue Dec 04, 2018 14:10
Yes, that will work great.
Thanks for getting me on right track, He2neg!
RyanD
Post by RyanD » Thu Dec 06, 2018 08:27
Thanks for info! :)
