no audio on "master output channel"
p8guitar
Post by p8guitar »
I have an audio clip running on layer 2. When I set the audio preferences to preview output channels = "Analog 1 (1) and Analog 2 (1)" and the focus is on layer 2, then I can hear the audio. When I set the audio preferences to master output channels = "Analog 1 (1) and Analog 2 (1)", I hear nothing (but still see the visual representation of the audio in the layer).
Is there somewhere a fader for the "master output channels", maybe it is set to zero? I cannot find the master output channels in the Resolume GUI.
Another problem: the volume fader of the layer does nothing (audio routed to preview output channels), it is alway full volume. Is this a problem related to the RME fireface 800 that I use? the audio output device is "ASIO fireface". I had expected that I could reduce the volume with the audio fader of the layer, but it doesn't do anything.
Re: no audio on "master output channel"
There is a separate audio volume slider in the Composition panel. And there is a Composition master opacity in the UI, which also fades the audio, so if you play your clip in the layer and don't see the output, chances are that it's turned down.
The Layer preview is indeed pre-fader, so you can check what's going on in the layer before fading it in.
p8guitar
Post by p8guitar »
Thanks for the explanation! Routing the preview audio pre-fader makes sense... ;-)
The volume fader in the composition panel was set to full volume, so I don't know what the problem wass.
All in all, the audio is quite unreliable. Today first I heard nothing, even on the preview audio. then I loaded a wav file in a clip, which could be heard, and then I could hear the video with the ffmpeg audio, too. Strange. Maybe the mpeg audio is causing this unsteady behaviour, I think Resolume doesn't like compressed audio. Or the fireface audio driver is unstable.
p8guitar wrote: Fri Jan 04, 2019 11:05 Maybe the mpeg audio is causing this unsteady behaviour, I think Resolume doesn't like compressed audio.
Indeed we recommend to use uncompressed audio.
Could you send us this file you had issues with?
p8guitar
Post by p8guitar »
Zoltán wrote: Fri Jan 04, 2019 13:18 Indeed we recommend to use uncompressed audio.
the files are 400MB, 1 GB and 4 GB... I will create shorter movies and send them. But today I could not reproduce the problem.
how do I send the files, per e-mail to mail@resolume.com?
Sent you a PM.
