Help with MIDI IN/OUT / Card MIDI
Aniro
Post by Aniro »
Hello,
I have a problem to configure my set up.
I explain what I did before and what I would need the X32 to do ( if possible )
Im using Ableton Live and feed 8 channels of the mixer with it through X-USB.
On another computer Im using RESOLUME.
With my previous sound card it was easy to make the 2 PC communicate.
My audio PC ran an USB to a Presonus / MOTU or RME interface ( with MIDI IN and OUT ports )
From that interface I would plug Roland UM3 MIDI/USB Cable from MIDI OUT to USB port of the VIDEO PC.
Then a simple Midi track in ableton would launch CUes or clips in Resolume , no big deal.
NOW my sound interface is the intergrated X USB and since the X32 got MIDI ports I was thinking I could do the same but cant figure how to.
I have my Audio PC connected to X-USB and the MIDI/USB connected to the video PC.Looks like what I did with the other interface.
And Its a big problem because I now need to launch sound and video cues at the same time ... with one finger .
Anyone has an idea how to reproduce my older set up with the X32?
PS.I really like the mixer though !
________________________
see more
Re: Help with MIDI IN/OUT / Card MIDI
If you are using Ableton, you could find the Max4Live patches useful to launch clips in Resolume via OSC from Ableton. https://resolume.com/blog/8717/max-for- ... me-patches
If Midi is your thing, then you could get the same behavior over a wired network between the machines.
Have a look at RTPMidi here: https://www.tobias-erichsen.de/software/rtpmidi.html
mowgli
Post by mowgli »
Are the patches working in Arena 6? I have no probs getting them to work with 5 but no luck with 6.
mowgli wrote: Sat Mar 09, 2019 19:26 Are the patches working in Arena 6? I have no probs getting them to work with 5 but no luck with 6.
Which version of the patches are you trying with Arena 6?
