4k benchmark
nickbeardo
4k benchmark
Post by nickbeardo »
Hi, i just downloaded the 4k benchmark - does it work with v7?
As i try to load it and nothing appears
Re: 4k benchmark
Yeah, the composition in the pack is still from version 4
That's not supported any more in 7.
You can create a new composition, make it 4k, and add 17 layers to it so it has 20.
Then drop the Clean files into column 1, and the noise files to column 2.
nickbeardo
Re: 4k benchmark
cool will do thanks
