MAX 4 LIVE Resolume Launcher - Not enough layers?
wearekloud
Post by wearekloud »
Hi everyone,
I'm new here to posting but i've been reading a lot and i can't for the life of me find out if there is a way to extend the max 4 live resolume launcher past 8 layers. The way i'm set up is that would only let me do 8 songs. I also see that it says 'column' but i can't find out what that does. Attached is a picture of what i'm referencing.
https://imgur.com/a/M6OeKLW
If anyone has any idea how I can control past 8 layers with Ableton into Resolume, you'd be a life saver. Thank you!
Re: MAX 4 LIVE Resolume Launcher - Not enough layers?
I guess you got this from here http://resolume.com/blog/8717/max-for-l ... me-patches
There is an instruction pdf on the page.
In the clip launcher you select the layer you want to launch clips in.
Then when you launch your clip #48 in Ableton, Resolume will launch clip #48 in the layer you selected.
How are you set up?
