[IMPLEMENTED in 7.22] Move column
hive8
Post by hive8 »
Add feature to move a column
Re: Move column
Click name of the bottom layers clip in said column, Shift+Click top clips name of said column, Ctrl+X, Ctrl+P on bottom layer empty cell of target column, Done (maybe 3 seconds)
Yay for old features ;)
You can also insert a blank column by right clicking the column and clicking "insert" before or after.
Re: Move column
hive8 wrote: Wed Dec 18, 2019 11:13 Add feature to move a column
+1!
Re: Move column
+1 with the ability to drag and drop similar to layers. It would also be amazing to be able to select multiple columns.
