scrolling text
alida
scrolling text
Post by alida »
How can I add scrolling bar of text to resolume, example, as they do on CNN/Fox lower thirds, from an external source? Am assuming we will need to write a plugin, that being said, any helpful feedback is appreciated
Empyfree
Re: scrolling text
Post by Empyfree »
You can push text into Arena over OSC. Touch designer could do text or CSV file to OSC. Lots of potential!
Re: scrolling text
You can also enter the text manually into the text animator source and animate the Position x
https://resolume.com/support/en/sources#text-animator
Re: scrolling text
For anyone needing csv to Resolume:
https://gumroad.com/l/csv_to_osc_pixel_party
