trigger next clip at the end of a loop
simsten
Post by simsten »
dear all!
Triyng to do something...
Play a loop clip a few times then I want to jump to the next (same layer), but only at the end of the current loop... using the "Trigger next clip" button.
Any solution ?
thanks a lot!
He2neg
Re: trigger next clip at the end of a loop
Post by He2neg »
Activate autoplay while the clip is running should do this... you also can use the yutopilot on the layer to have the same toggle with multiple clips
~Berlin~
simsten
Post by simsten »
Thanks,
that's what I actually do but need to turn the autopilot (on layer) off each time I jumped, to have the new clip in loop mode till I want to jump to the third etc...
I d'like kind of a "jump next loop at the and of that loop" button! (Like you can easily do in Ableton Live for exemple...)
The best way I found for the moment is to link my Ableton with my Resolume (play next clip link to next scene in Ableton) and it works well, but wondering if Resolume can do this alone!
Have you tried Beat snap?
https://resolume.com/support/en/clips#beat-snap
That's what Ableton does too afaik.
