Couple of teasers for you
Light FX UK
Post by Light FX UK »
no 1. set each clip to strobe in beat with the track without human intervention even when the bpm changes.
no 2 - get the column to change every say 4 bars on the beat of the track
might need external software solution for this but braced for it :-)
Ty in advance. Keep happy people we're near the end of this 'orrible time.
Re: Couple of teasers for you
Should both be doable in Resolume ;)
1. Solid color effect with opacity set to BPM animation https://resolume.com/support/en/parameter-animation
2. Auto pilot with the clips set to BPM sync and Composition beat snap set to 4 beats (1 bar) https://resolume.com/support/en/clips#auto-pilot
https://resolume.com/support/en/clips#beat-snap
