alpha premult issues
vjmandala
Post by vjmandala »
Hi, having some issues importing a sequence with an (Straight not Premult) alpha channel embedded.
Rendered out of Davinci with Straight Alpha. In Fusion Studio I can see full RGB channel.
When I place directly into Resolume or Alley it Premults, leaving unwanted black RGB info around eye.
Any help most welcomed. Cheers.
Rez7
Rez7
Alley
Alley
Fusion
Fusion
still pushin piXels...
Re: alpha premult issues
When you fold open the extended properties, you get access to Opacity, Width & Height, Blend Mode and Alpha Channel interpretation of a clip.
https://resolume.com/support/en/clips#video-properties
Képernyőfotó 2021-09-10 - 10.09.17.png (52 KiB) Viewed 3462 times
vjmandala
Post by vjmandala »
Awesome thanks. Part of my issue was also rendering the MOVS as DXV with straight alphas in the firstplace. Both ends of the issue work now. Thanks again mate.
