How do I trigger a random clip on a layer?
booshtukka
Post by booshtukka »
Can it be done?
Re: How do I trigger a random clip on a layer?
Place a Solid color source to the layer, set it to transparent color, and 0,1s duration.
Set it's Autopilot to Random clip, https://resolume.com/support/en/clips#auto-pilot
trigger Solid color clip
booshtukka
A bit crazy, but works, thank you! :)
gpvillamil
Post by gpvillamil »
booshtukka
This works perfectly. However, I have one clip basically set to black so I can easily turn the layer off. Is there a way to set Autopilot to a Random clip, but giving it a series of clips? i.e. Random EXCEPT this one :)
I found myself in a similar situation where I want to say "Random between these three" too.
tijnisfijn
Post by tijnisfijn »
Just map the layer blackout button to a keyboard key or midi button instead of using a black clip.
booshtukka
Fair! I’ll try this thank you. :)
booshtukka
This works perfectly - except I'm using BPM sync. So when I trigger the random clip, I get a black screen until the beginning of the next bar. Is there a way to have a clip start in the middle of the bar but stay in time if I trigger it off-beat?
booshtukka wrote: Thu Aug 03, 2023 11:42 This works perfectly - except I'm using BPM sync. So when I trigger the random clip, I get a black screen until the beginning of the next bar. Is there a way to have a clip start in the middle of the bar but stay in time if I trigger it off-beat?
I answered this on your other post with the same question.
