Hi, thank you for adding REST API! This could be gamechanger for developers.
I'm working on developing REST API with Golang(https://github.com/FlowingSPDG/resolume-go).
I found that "value" field in "BooleanParameter" struct is not actual boolean value.
When I access http://localhost:8080/api/v1/composition , Actual BooleanParameter value is "Empty", which is not boolean.
I'm still trying to find more possible bugs, will post here if I found any.
Incorrect API response type
Re: Incorrect API response type
"bypassed":{"valuetype":"ParamBoolean","id":1640951645300,"value":false} is what I see a lot.
Do you have a specific composition where it says empty for you for bool?
HiiragiNil
This bug can be replicated on MacOS Catalina 10.15.7 with Resolume Arena v7.8.0.
I had this bug on example project (/Users/flowingspdg/Documents/Resolume Arena/Compositions/Example.avc).
Here is full JSON response of /api/v1/composition .
https://pastebin.ubuntu.com/p/J2gtKCDdkm/plain/
I guess "Clip" has incorrect type.
layers.clips.connected type should be "BooleanParameter" but it has "ParamState" type, which is not defined in swagger.
"connected":{
"id":1641335430528,
"valuetype":"ParamState",
"options":[
"Empty",
"Disconnected",
"Previewing",
"Connected",
"Connected & previewing"
"index":1,
"value":"Disconnected",
"id":1641335430527
https://user-images.githubusercontent.c ... 3e122f.png
https://user-images.githubusercontent.c ... ac7800.png
https://user-images.githubusercontent.c ... fbf9c3.png
"connected":{
"id":1641335430528,
"options":[
"Empty",
"Disconnected",
"Previewing",
"Connected",
"index":1,
"id":1641335430527
A clip slot can be connected multiple ways, like the list explains. It should not be a bool.
HiiragiNil
I see, okay then I need correct swagger yaml for generating correct typed codes.
The problem is not if its bool or not, it is different type from swagger.yaml's type definition.
My Go project codes are generated automatically by reading swagger's types, so if type is not matched my code will be broken. Otherwise I have to fix them by myself, which means swagger is not working.
Hmm, I see what you mean now.
I'll make a ticket.
I'll make a ticket.
HiiragiNil
Thank you! imo swagger is best API definition tool because many tool supports auto code generation.
I just wanted to tell you it is awesome to have auto-generate work for many programmers/developers.
API looks game changer for resolume users, thanks and keep it up!
