Remote control and content load
andre
Post by andre »
Hi all
I'm thinking about buying Resolume Arena for our ledwall, but I want to install the hardware behind it and control it from the front.
I've read that some of you uses VLC or OSC, but in this way I will have to go on the back of the ledwall every time I need to load a new content.
Isn't there a manger producer like Pandora's Box or Watchout have?
Thanks,
Andre
Re: Remote control and content load
Yes, with the API you can load files to clips slots remotely. and control UI features.
https://resolume.com/support/en/restapi
andre
Post by andre »
Zoltán wrote: Fri Feb 11, 2022 17:38 Yes, with the API you can load files to clips slots remotely. and control UI features.
Do you mean that I need to develop my own uploader or can I upload files in the web interface?
You can use curl in terminal or a command line to call the web address, so you don't necessarily need to develop.
https://resolume.com/docs/restapi/#/clip/clip_openfile
Something like this should do it
curl -X POST http://[IP_Address]:8080/api/v1/composition/layers/1/clips/1/openfile -d "file://[File_absolute_path]"
andre
Post by andre »
Zoltán wrote: Fri Feb 11, 2022 18:32 You can use curl in terminal or a command line to call the web address, so you don't necessarily need to develop.
Well, not really user friendly.
Thanks for pointing be to this possibility
You can also use VNC to connect to the machine ;)
