Fade Out (Envelope) when using Piano Trigger
sbbbuehq
Post by sbbbuehq »
Hey there!
I have the following situation in Arena:
I have some clip, e.g. a Solid Color Generator and the Trigger is set to Piano (press and hold). I can use the Timeline Setting + Envelope on the Clip's Opacity parameter to create a FadeIn Effect. I wonder if there is a (either native or workaround) way to have a FadeOut as well. But mind the Piano Trigger: The FadeOut should only begin after releasing the button.
I am open for any kind of suggestion. Clean solutions are preferred but I am also interested in seeing how you think Arena out of the box. :D
Re: Fade Out (Envelope) when using Piano Trigger
Maybe map the opacity vs the clip?
sbbbuehq
Post by sbbbuehq »
@Arvol:
Just out of curiosity: what do you mean by "vs the clip"? Changing "Timeline" back to "Basic"? But then it won't move, does it?
@Zoltán
Thanks a lot! That's exactly what I was looking for. (I didn't know this view existed - it is not part of the training at https://resolume.com/training, is it?)
Yeah, the support page is a lot more detailed ;)
