SMS to resolume
Brewer551
SMS to resolume
Post by Brewer551 »
Hello everyone,
We have a project where we have a database with text messages. We can export them in any format or synchronize them with an API (if it's the case). We would like to display them on a screen in realtime.
Is this doable with Resolume? Should I look at TouchDesigner? Can anyone offer a technical solution that would make this feasible?
Thank you,
Re: SMS to resolume
Check out the REST API: https://resolume.com/support/en/restapi
You also probably want a moderation step there ;)
