I want to play large(40Gb) 4K H.265 encoded video. Arena only shows the AudioStream under "Clip". I have tried this on different 3 PCs(Windwos 10 and 11). Same behavior. 1 PC was a complete fresh install. On my Mac, the video plays correctly.
Legacy Windows Media Player, Media Player and VLC play the video correctly.
the video is from a Gopro Hero 11... no video of the gopro works
H.265 Video
Re: H.265 Video
Resolume does not play h265 files, h264 is possible but not recommended.
You should convert your footage to dxv3 for best performance.
Re: H.265 Video
Resolume plays DXV, and prores natively. Other formats are played through the OS media libraries. If the Windows Movies and TV can play the file there is a good chance, Resolume could too.
You might need to install a third party codec for h265.
Re: H.265 Video
Know this is an old thread but we're moving from ProPresenter to Resolume and got over 1000 files (90Gb) of H.265 background loops which play fine on mac & PC. Got 400 older H264 files which play ok.
Is there any update / fix to getting these to play as don't fancy converting them all.
