Reset Resolume Arena to factory
djspynn
Post by djspynn »
Hey all, just started messing around with resolume arena and messed up a setting I can not find. Trying to reset the software so it will stop. Not sure what the next step is. What I was trying to do is create a fade transition so it'll fade from image to image...
Re: Reset Resolume Arena to factory
What's happening exactly, that you'd like differently?
Did you maybe change the Auto pilot settings? https://resolume.com/support/en/layers#auto-pilot
Renamming the Documents/Resolume Arena folder pretty much resets everything except the clip thumbnails and registration.
There is a preferences folder in it, which has the program settings in it.
Here is our full folder list: https://resolume.com/support/en/directory-list
