new in Arena7 and a lot of question
goldendye007
Post by goldendye007 »
sorry, I'm newbee and have some question. I can't found it anywhere:
- still images: auto playtime ? ( in chase. I want to play a image only for 8sec than fade out )
- clips: fade in / fade out with time for individual clips or only for layers?
- auto play next clip / layer / column after specified time ?
thanks for the first questions :-)
kalli
Soeri
Re: new in Arena7 and a lot of question
Post by Soeri »
territorial ioSame to you.
Our support page would answer these:
goldendye007 wrote: Fri Jun 23, 2023 10:37 - still images: auto playtime ? ( in chase. I want to play a image only for 8sec than fade out )
https://resolume.com/support/en/video#playback look for Duration
goldendye007 wrote: Fri Jun 23, 2023 10:37 - clips: fade in / fade out with time for individual clips or only for layers?
https://resolume.com/support/en/layers#layer-transition
goldendye007 wrote: Fri Jun 23, 2023 10:37 - auto play next clip / layer / column after specified time ?
https://resolume.com/support/en/layers#auto-pilot
goldendye007
ok, that's work only when a clip is in. when I want to go only in black? I need a solid png?
and . . . is it possible to have different fade in / fade out times for a layer. In this case:
Layer 3 - fade in clip 3sec - fade out in 6 sec?
thx again
goldendye007 wrote: Thu Jul 06, 2023 09:09 ok, that's work only when a clip is in. when I want to go only in black? I need a solid png?
or a transparent solid color source, and it's duration will play with auto pilot too.
goldendye007 wrote: Thu Jul 06, 2023 09:09 and . . . is it possible to have different fade in / fade out times for a layer. In this case:
thx again
Setting that to happen automatically is not possible at this time inside Resolume.
