power outage - midi not working
elfanroberto
Post by elfanroberto »
Last night I had a power outage and from then on I could never recover the project I was working on. That is, it was still in the compositions folder but it did not open, nor did it appear in my compositions list within the program so I could not extract the deks. Opening the composition in the notepad I could see that it did not finish saving all the information, I think it is because I was saving the project when the power outage occurred. Now I realize that the midi controller doesn't work for me either, I mean, it recognizes it but there is no way to make it work. I need to solve this. I have opened a new project and started from scratch, but I can't get the midi to work
- nanoKontrol2
[2023-12-15T13:18:18.729-03:00] INFO: Previews Path: C:\Users\Seba\AppData\Local\Resolume Arena\previews
[2023-12-15T13:18:18.729-03:00] INFO: Print system info
[2023-12-15T13:18:18.729-03:00] INFO: Operating system: Windows 10
[2023-12-15T13:18:18.729-03:00] INFO: VersionInfo (unreliable): 10.0.19045
[2023-12-15T13:18:18.729-03:00] INFO: OS 64 bit: Yes
[2023-12-15T13:18:18.729-03:00] INFO: CPU vendor: GenuineIntel
[2023-12-15T13:18:18.810-03:00] INFO: CPU speed: 3983MHz
[2023-12-15T13:18:18.810-03:00] INFO: Number of CPUs: 8
[2023-12-15T13:18:18.810-03:00] INFO: Memory size: 32721MB
[2023-12-15T13:18:18.810-03:00] INFO: System language is: es
[2023-12-15T13:18:18.810-03:00] INFO: Locate preferences directory
[2023-12-15T13:18:18.810-03:00] INFO: Locate settings file
[2023-12-15T13:18:18.811-03:00] INFO: Copy Default Effect, Source, Envelope, Color Palette, Layout, Advanced Screensetup Presets if needed
[2023-12-15T13:18:18.834-03:00] INFO: Could not extract version
[2023-12-15T13:18:18.839-03:00] INFO: No Default Presets copied!
[2023-12-15T13:18:18.839-03:00] INFO: Load Application settings
[2023-12-15T13:18:18.840-03:00] INFO: Install languages
[2023-12-15T13:18:18.843-03:00] INFO: Get Typeface specified by language and set for LookAndFeel
[2023-12-15T13:18:18.843-03:00] INFO: NotoSansRegular_ttf resource size in bytes : 313144
[2023-12-15T13:18:18.843-03:00] INFO: NotoSansBold_ttf resource size in bytes : 313792
[2023-12-15T13:18:18.843-03:00] INFO: NotoMonoRegular_ttf resource size in bytes : 107848
[2023-12-15T13:18:18.845-03:00] INFO: createSystemTypefaceFor for typeFaceData.regular succesful : Noto Sans Regular
[2023-12-15T13:18:18.847-03:00] INFO: createSystemTypefaceFor for typeFaceData.bold succesful : Noto Sans Bold
[2023-12-15T13:18:18.848-03:00] INFO: createSystemTypefaceFor for typeFaceData.mono succesful : Noto Mono
[2023-12-15T13:18:18.848-03:00] INFO: Init Colour scheme for user interface
[2023-12-15T13:18:18.848-03:00] INFO: Create LookAndFeel
[2023-12-15T13:18:18.850-03:00] INFO: Set LookAndFeel
[2023-12-15T13:18:18.851-03:00] INFO: Create InputReceiver
[2023-12-15T13:18:18.851-03:00] INFO: Create ApplicationController
[2023-12-15T13:18:18.853-03:00] INFO: Creating NDIVideoServerManager
[2023-12-15T13:18:18.853-03:00] INFO: Initializing NDI library
[2023-12-15T13:18:18.861-03:00] INFO: Successfully initialized NDI library
[2023-12-15T13:18:18.869-03:00] INFO: Created NDIVideoServerManager
[2023-12-15T13:18:18.877-03:00] INFO: Load HelpController file
[2023-12-15T13:18:18.878-03:00] INFO: Create AudioEngine
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Bitcrusher.dll
Creating VST instance: Bitcrusher
Initialising VST: Bitcrusher (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Distortion.dll
Creating VST instance: Distortion
Initialising VST: Distortion (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\EQ-3.dll
Creating VST instance: EQ-3
Initialising VST: EQ-3 (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Flanger.dll
Creating VST instance: Flanger
Initialising VST: Flanger (1.1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\HighPass.dll
Creating VST instance: HighPass
Initialising VST: HighPass (1.0.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\LowPass.dll
Creating VST instance: LowPass
Initialising VST: LowPass (1.0.0.0)
[2023-12-15T13:18:19.146-03:00] INFO: Install Audio Effect Preset preprocessor
[2023-12-15T13:18:19.146-03:00] INFO: Update Composition List
[2023-12-15T13:18:19.431-03:00] ERROR: ra::XmlUtils::loadXmlFromFile: Exception thrown parsing xml document 'C:\Users\Seba\Documents\Resolume Arena\Compositions\booooo.avc'.
[2023-12-15T13:18:19.432-03:00]WARNING: CompositionInfo::parse() ra::loadXmlFromFile failed!
[2023-12-15T13:18:19.778-03:00] INFO: Enumerating Compositions took: 0.63245 seconds
[2023-12-15T13:18:19.779-03:00] INFO: Initializing OSC
[2023-12-15T13:18:19.794-03:00] INFO: Create MidiController
[2023-12-15T13:18:19.803-03:00] INFO: Libwire API version: 7
[2023-12-15T13:18:19.803-03:00] INFO: Expected API version: 7
[2023-12-15T13:18:20.379-03:00] INFO: Install Video Source Preset preprocessor
[2023-12-15T13:18:20.379-03:00] INFO: Install Video Effect Preset preprocessor
[2023-12-15T13:18:20.379-03:00] INFO: Install Animation Preset preprocessor
[2023-12-15T13:18:20.380-03:00] INFO: Loading Animation presets
[2023-12-15T13:18:20.418-03:00] INFO: Loading Render and Recording presets
[2023-12-15T13:18:20.418-03:00] INFO: Loading Render presets
[2023-12-15T13:18:20.420-03:00] INFO: Load AudioEngine settings and initialise audio engine
[2023-12-15T13:18:20.420-03:00] INFO: Changing audio setup to:
[2023-12-15T13:18:20.420-03:00] INFO: Device Type: Windows Audio
[2023-12-15T13:18:20.420-03:00] INFO: Output Device: TV-monitor (NVIDIA High Definition Audio)
[2023-12-15T13:18:20.420-03:00] INFO: Input Device: None
[2023-12-15T13:18:20.420-03:00] INFO: Samplerate: 48000
[2023-12-15T13:18:20.420-03:00] INFO: BlockSize: default
[2023-12-15T13:18:20.421-03:00] INFO: Output Channels: 11
elfanroberto
Re: power outage - midi not working
solved, the midi preferences have been deconfigured, I had to uncheck the clock signal input. I lost the project definitively but the midi is perfect
Power outages can cause issues like this, especially with MLC SSDs but also when the OS write buffer hasn't been pushed to the disk yet.
An UPS is a great investment.
If the composition file is readable, you probably can save what's there, by removing the last open <clip section, and adding
</deck>
</composition>
to the end of the file.
