DXV format and Preview Tool
Mstark
Post by Mstark »
Hi All,
I like to review all my video files in one application for easier management. However, Windows doesn't recognize DXV (Resolume) or ProRes4444 (Apple), (which are only formats that support Alpha channels). This means no preview is generated, requiring different applications for review, which isn't ideal.
Adobe Bridge, a free tool from Adobe, supports Apple formats but not DXV, leading to the same problem.
However, Dropbox does recognize DXV and other formats! They have revamped their interface to facilitate review workflows. See the attached screenshots of the Resolume render file folder files with Dropbox.
It makes sense to use DXV, considering memory requirments and quality (see attached) and it's amazing that Dropbox can read all the formats. Maybe this was common knowledge, but i wish id known sooner...
Good Luck!
Re: DXV format and Preview Tool
If you're Windows based, there's a shell extension that allows you to preview from your Windows Explorer. OSX I don't think has a solution as apple keeps crewing things up.
basicpermit
Post by basicpermit »
This is exactly the information I was looking for now. Thanks I was able to view the information on my Windows. :) geometry dash subzero
tijnisfijn
Post by tijnisfijn »
For Mac there is this..... which gives you at least thumbnails of the first frame. it still doesn't give a preview, but it's more than just a empty icon.... https://github.com/Marginal/QLVideo#readme
Mstark
Post by Mstark »
I did not know, can you provide a quick 1. 2. step instruction on how to get that extension working? much appreciated. and thanks
tijnisfijn
Try this... Then you must be able to figure it out...
https://github.com/Marginal/QLVideo/wik ... ng-Started
kernuo
Post by kernuo »
Is there any alternative for macbook users?
theLABVisuals
Post by theLABVisuals »
Arvol wrote: Tue Jun 04, 2024 23:42 If you're Windows based, there's a shell extension that allows you to preview from your Windows Explorer.
Windows - https://www.videohelp.com/software/Icaros
