vertical text
marco@mplive.it
vertical text
Post by marco@mplive.it »
Greetings,
Is it possible to write text vertically?
I mean each letter oriented horizontally but one below the other to form a colonnaded text
looking at the attached image, like the letters on the right side
thank you very much
tijnisfijn
Re: vertical text
Post by tijnisfijn »
Hi Marco
Not with the standard effects and tools in arena, but you could make a plugin in wire that could do it. Or, of course you could use one letter per line but that's a workaround... If you don't have a wire license, I could share of you a plug-in that I made but the problem is that you cannot change the font in arena. So the font needs to be set in advanced in Wire.
marco@mplive.it
Thank you
Greetings,
Unfortunately I don't have the software available, I'm installing the LED wall, we rented a server with an operator" but he told me that the vertical text couldn't be done, so I'm inquiring at the same time, if you can send me the plugin I would be very grateful, then I pass it on to the technician who takes care of the videos.
However, I'm considering purchasing it because lately I have many events with the ledwal divided into multiple columns and renting the server with the operator is becoming a big expense and today I would have already purchased many licenses
Thank you very much
Re: vertical text
marco@mplive.it
thank you very much
thank you very much,
it's exactly what I needed, now I'll forward the link to the technician.
Thanks again very much
Grimm90
Re: vertical text
Post by Grimm90 »
@Zoltan , you are such a smart cookie, thanks a lot <3
