Autopilot issue
zaniz
Autopilot issue
Post by zaniz »
Hi Guys !
I have a gig with lots of led panels, in one of them, I want to show about 30 loops automatically in sequence while I play the other led panels with the music.
I create a composition with 4 layers in 2 groups. layers 1, 2 and 3 in one group for the majority of the led panels. Layer 4 is in a group exclusively for the 30 loops automatic sequence for a single led panel, these loops are set to play next clip automation, with the last one set to return to the first loop to restart the sequence. I use 2 groups for the effects in one group dont affect the other group.
This 30 loop sequence works fine while I stay in the deck where all the 30 loops are.
My problem is when I start to play loops in other decks for the rest of the panels (layers 1,2 and 3), the automation in layer 4 stops. If I get back to the deck where all the 30 loops are, the sequence automation restart
I just want to play loops in other decks while the automation runs in background changing loops in layer 4, is this possible ?
Thanks for the attention
Re: Autopilot issue
Decks which are not loaded, don't have the clips loaded.
Set the clip you want to keep playing in auto pilot after deck switch to persistent.
https://resolume.com/support/en/clips#persistent-clips
zaniz
Re: Autopilot issue
Post by zaniz »
I put al the 30 loops in persistent mode and now everything works.
Many Thanks Zoltan !
