Set speed on dashboard
atlibolla
Post by atlibolla »
thanks for the consistently best online support in the world!
I have a quick question:
I have an effect with the opacity bpm synced and an envelope. So the effect comes on for a beat and then goes off for three beats. I can map the speed slider via MIDI but I can't seem to link that speed slider to a dial in the dashboard. Is that not possible or am I missing something?
Thanks in advance!
A.
atlibolla
Re: Set speed on dashboard
Post by atlibolla »
So no way of assigning the speed slider to a dashboard dial? May I enquire why, since it's so easily MIDI mappable?
Speed is a property of a parameter. It's not a parameter by itself. If it would be it would have to have it's own animations with it's own speed, and so on..
