Registration file won’t won’t write
Liberty Church
Post by Liberty Church »
Problem is on Mac. I’ve checked writing permissions and everything appears fine. I’ve tried both online and offline registration.
vejas
Re: Registration file won’t won’t write
Post by vejas »
A quick test/fix, try to create another user with admin credentials and see if it's works.
Usually a permission issue.
Delete the
Code: Select all
/Library/Application Support/Resolume Arena
folder and reinstall Resolume using a new installer from our download page for your version.
Also make sure Resolume has full disk access in the OSX privacy.
