Consolidating a patch with image resources only saves a .wired file?
glitchkid8711
Post by glitchkid8711 »
Hey gang,
i was looking to share some patches that used image resources, however when i used the consolodation function (as per the youtube vid) the folder only contains a uncompiled .wired file for wire? what is the correct method to share patches with resources to resolume users? if i compile a patch to the same folder will it read the resources correctly? unfortunately i dont have a second machine to test atm.
tijnisfijn
Re: Consolidating a patch with image resources only saves a .wired file?
Post by tijnisfijn »
You can use the consolidate function, but save it to a different folder as your patches, for instance, the desktop, then it should get all the image resources that you use into that new folder.
".wired" is a compiled file https://resolume.com/support/en/wire-sa ... solidating
It will have the resources inside.
Consolidation is different, it collects data to a specific folder.
