Wire Tutorial Crashes
vynn
Post by vynn »
Hi everyone,
I just started trying out resolume avenue and wire to get more into VJ'ing and visual design. I got through the first few fundemental tutorials of Wire without any problems. Now, I am going through the basic tutorial section - where stuff gets more complex - but the program keeps crashing when I slightly adjust just some parameters or when I open another tutorial. I think my computer has the specs needed to run all of this so I suspect a software bug or overload within Wire itself.
Has someone encountered this as well, does anyone has suggestions on how I can fix this?
Let me know, because this is obviously annoying :D
Christoph
Re: Wire Tutorial Crashes
Post by Christoph »
Do you see a crash reporter popup when it crashes?
What operating system and what graphics card are you on?
vynn
Post by vynn »
Christoph wrote: Tue Nov 18, 2025 16:40 Do you see a crash reporter popup when it crashes?
Hi Christoph, thanks for responding.
Yes it pops up, but the crash reporter pops up twice immediately after the crash.
Maybe that could suggest a problem?
Regarding my OS and the graphics card, I'm using Windows 11 Home and NVIDIA Quadro P2000 which are updated to the latest version.
Christoph
Post by Christoph »
This sounds a lot like viewtopic.php?t=32074
This crash should be fixed in 7.24 once this is released.
In the meantime you can try downgrading to Nvidia driver 560.76 or 527.27
