Resolume 7.25 Release 🚀 Individual Clip Transitions 🎯 Slice Transform Effect Update
We have a little confession to make: our previous release, 7.24, was a bit of a struggle. Our beta testers can confirm that there was a lengthy test period required in which we had to fix quite a bit of regressions and fine-tune the new features.
Frankly, 7.24 was just too big with too many new features to properly oversee it all. We got it to all work properly in the end but it took way longer than we wanted, keeping you waiting for new updates…
So our New Year's resolution for 2026 is to do smaller releases, but more frequently. And this version, 7.25, is an example of that, just a few nice new features and bug fixes, nothing more, nothing less, just perfect, we think. Enjoy!
Individual Transition Time & Blend Mode for Clips
Until now, transition time was something you could set per layer. But many of you told us you wanted more control per clip, because not every clip deserves the same smooth fade. You can now set an individual transition time and blend mode per clip, so you can keep your layer transition consistent while letting special clips enter exactly how you want. To make this work, we've added a Transition tab to the Clip panel.
Scale & Position Parameters in Slice Transform Effect
The Slice Transform effect now includes Scale and Position controls, letting you push, pull and resize slices with a lot more precision. Additionally, slices & screens can now be previewed, just like effects and sources, by double clicking on them in the Slice panel. And because the slice panel can get busy fast, you can now fold or unfold all slice tabs at once with a simple Shift+Click.
Faster, Again and Again and Again
This version, again, runs a bit faster. Especially on big compositions with 40+ layers, 500+ columns, you'll notice loading is faster and going into MIDI/Keyboard mapping is also snappier.
Wire Multi-Node Workflow
"Multi" is the name of the game for this Wire update.
You can now expose inputs and edit attributes for multiple nodes at once.
Renaming gets a boost too: you can rename multiple nodes and use an @ or # suffix to automatically add alphabetical or numerical labels after the name.
Wire Arithmetic Math Shortcuts
We've also added (numpad) shortcuts to insert arithmetic nodes: Add (+), Subtract (-), Multiply (*) and Divide (/). This also works with multiple selected nodes, automatically adding channels and wiring everything up.
Duplicate Node and Keep the Connections
You can now duplicate a node AND keep the connections by pressing SHIFT + D or by dragging a node while holding OPTION/ALT + SHIFT.
Avenue/Arena 7.25.0 Fix List
- OBS virtual camera not working on Windows
- Deck select with specific OSC shortcut preset can send out unknown type tag to slave, slave selects wrong decks
- Nearest Sampling on Resize node does not work when patch is running in Arena
- Juicebar compiled effects don't show up in Arena with UTF-8 username
- Wire mixers and render passes that are deleted and undeleted show up with a "(1)" behind their display names
- Slice transform mask invert should mask to transparent
- Fold slices in Slices Panel
- Enabling OSC input and output is not effective if it was disabled on startup
- Undo breaks with column moves
- Keyboard shortcut to make snapshot of selected clips/nodes
- Crash loading vertical MP4
- Double clicking composition in Finder should open it up with Arena not running yet
- Clip in- and out-points change when replacing clip
- Update thumbnails via REST API
- Assigning color to audio effect is not working
- Auto-update can fail if Adobe apps are not installed
- Remove "New Mixer" option from layer menu
- Ignore column trigger on group columns is not restored/saved properly
- Crash searching for ?
- This patch with ISF freezes Arena
- Collected folder with Chinese characters doesn't connect relative media
- APC40 mkII shortcut preset shows weird column colors when loading composition
- Blackmagic HDMI recorder not able to open 2560x1440p60 in RGB anymore
- Vertical ProRes 4444 files crash Arena on opening them on Windows
- DeckLink input RGB / SMPTE mode was flipped
- Transform widget not working on layer monitors
Wire 7.25.0 Fix List
- Filtering options on texture material
- Subtract blend mode is missing from Video Mixer and Transition nodes
- Compiled patches are a lot slower than regular ones with many concurrent file playbacks
- Add Texture support to boolean operation nodes
- Insert Pack not working in attribute flow
- Insert Pack for single-channel textures
- Make scroll bar handle in node output preview wider, so it's easier to grab
- Crash loading lots of file resources
- Smooth Node: Add default value and reset options
- Pixel Blur Intensity texture applied incorrectly
- Crash switching Slice in input from pasted nodes
- Edge output with Slices where some have masks is incorrect
- bad_optional_access error when Scale is 0,0 on Transformation 2D into Camera 2D
- Crash with comment and cmd/ctrl + enter
Alley 7.25.0 Fix List
- Alley starts too many concurrent H.264 conversions
cat
Re: Resolume 7.25 Release 🚀 Individual Clip Transitions 🎯 Slice Transform Effect Update
Post by cat »
Transition is labelled blend more, should be transition type really, to differentiate in a hurry what you are setting. But the fix list looks great, thanks.
Ah, just been trying it out, and once I have set a clip to a defined transition, switching decks to do another clip, and the clip transition stays as the last one set ie layer determined check box is unticked and 'blend mode' remains set, although it doesnt seem to affect the next clips transition, that will get confusing... Each clip needs to be set to determined by default, I'm guessing no value = that, but that the gui doesn't update without a value set?
Should the transition be marked as none changed by the clip like it is with blend mode?
kman1898
Post by kman1898 »
bart wrote: Thu Mar 19, 2026 12:32
Does this mean we can now have pixel to pixel scaling? As the old slice transform would scale content regardless of if it was pixel to pixel to the slice transform. I had to make my own wire plugin to combat this issue and it’s works great. But native sounds better.
cat
Post by cat »
OK, transitions per clip seem very buggy. I've set all of them, go back through my decks, and the values aren't persistent, it seems more like setting per clip slot, not per clip, but even that isn't consistent.
Its seems like some get taken and some dont, I just set a clip to 0 and went through each individually on that layer, switched decks came back and back and a couple were back at the value they had before. Did it again, went back through without switching decks and one was still wrong. I think your dictionary isn't getting updated correctly.
And again, another deck has multiple clips with the wrong values ( that I have used on a different layer, never this one). I'm going to roll back
Online
Christoph
Post by Christoph »
We're having a look at the clip transitions across decks, thanks!
