Doepher Pocket Fader
jesse_
Post by jesse_ »
What settings on the Pocket Fader do I need set to make it work with Resolume? Any one have one?
The fader says it's transmitting volume data on each channel (1-16) but it isn't selected in Resolume when I go into the MIDI preferences part... Ideas?
:: jesse
edwin
Post by edwin »
what do you mean by, 'it isn't selected'!
Do you mean that the device is not listed in the midi-devices list on the midi-general tab?
Or do you mean that you can't assign the controllers of the pocket fader to functions listed in the midi-controllers list on the midi-notes tab?
jesse_
Post by jesse_ »
I can't assign controls of the fader to the functions.
iv0_
Post by iv0_ »
Hello,
I have the same problem - I do not have my midi command station (PEAVEY PC 1600x) listed in the midi-devices list on the midi-general tab.
How do you connect this PEAVEY to your computer? through USB?
