Resolume Avenue 3.3.1 and DXV Codec 2.1.1 Released
There is a Dutch expression that says "Those who do not honor the small, are not worthy the big". So today we are releasing a small update for Avenue and a (not so small) update for the DXV codec.
Avenue 3.3.1 fixes a number of small bugs that have been annoying us for while and we're happy to iron those out. DXV 2.1.1 fixes quite a few compatibility issues when rendering video with various applications. It now works great with Adobe After Effects, Media Encoder, Sony Vegas, Ableton Live (yes, Live edits video too) and our personal favorite: Apple Motion!
Hit the download, and remember to honor the small things in life ;-)
CORRECTION: DXV version 2.1.1 not 2.2.1 ;-)
Enjoy!
The Resolume Team
Release Notes Resolume 3.3.1
[FIXED] Feedback sources don't remember their size settings
[FIXED] Unregister DMX unregisteres Resolume serial
[FIXED] New effects added to effects tab don't show in gui
[FIXED] Mapping for bpm tap buttons are not saved in composition key map
[FIXED] Invert for composition beats doesn't do anything
[FIXED] No alpha in feedback
[FIXED] The first time a clip is triggered after startup the clip
thumbnail isn't shown in the layer
[FIXED] Timeline zoom shows incorrect clip after zoom out
[FIXED] Can't register dmx serial offline
[FIXED] Register offline, some text overlaps after registration
[FIXED] Switched channel 5 and 7 in DMX Automap
Release Notes DXV Codec 2.1.1
[FIXED] Apple Motion crashes when rendering with DXV
[FIXED] Can't access DXV settings in Sony Vegas
[FIXED] Sometimes frames in wrong order in Adobe Media Encoder CS4
[FIXED] Crash QT 7.6.6 on WIN7 64
[FIXED] Sometimes flipped frames
[FIXED] DXV 2.1 crashes some apps on windows when loading older DXV files
[FIXED] DXV 2.1 does not render alpha correctly in Vegas
[FIXED] DXV 2.2 still gives quicktime error on AE CS4 (image sequences)
[FIXED] Windows 7 AE CS5 does not remember the codec settings
rxfromparis
Re: Resolume Avenue 3.3.1 and DXV Codec 2.2.1 Released
Post by rxfromparis »
great work guys :)
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
Tschoepler
Post by Tschoepler »
hurray :!:
massta
Post by massta »
I was converting all my videos into DXV Codec using Quicktime Pro with no issues.
I will update to this release, but my old videos should be fine, right?
Looking forward to MIDI OUT capabilites so my BEHRINGER: BCF2000 motor sliders can respond to software parameter changes.
~Shawn
VJair
Post by VJair »
yeah, your old vids will still play fine. its a point update, so it just fixes bugs.
edwin wrote: When we will implement OSC out we will also have to implement MIDI out. This is something which is high on our todo list but something that will not be implemented before version 4.
massta
Post by massta »
Thank you very much for the quick response and look forward to future builds. You guys are doing a fantastic job.
Basic
Post by Basic »
good news just as my new mac is about to drop.... :)
oau
Re: Resolume Avenue 3.3.1 and DXV Codec 2.1.1 Released
Post by oau »
OOooohh!!!! really, really THANKS! for correct the ableton dxv export. The best notice for me today and maybe the rest of the month :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P
gpvillamil
Post by gpvillamil »
Awesome, this is great! Is the final 3.3.1 the same that was sent to testers? (ie. should I download it if I already downloaded the one that was sent for testing?)
It's the same (rev 3055), so no need to download it again :)
