Hello!
I've been looking around but can't find the solution, a least not quite.
I use different setups with Resolume Arena 7, one of which involves sending MIDI signal from Ableton Live through a MIDI "agregate". I also use an Akai APC 40, Akai Mini or Korg Nano. Different setups for different projects...
The thing is depending on the type of project, I have different notes set to trigger videos in Arena, there can be in different spots as well. But whenever I change it in one composition, it applies to all the others I open afterwards. It means that every time I work on a new project, and go back to an older, I need to remap the whole MIDI, it's quite time consuming...
I found some of the MIDI profiles on my computer, there are four saved (not sure how I can save them) but the one named "default" always appears.
So, my questions are:
1. How can I load a MIDI profile to a composition? I've read through shortcuts menu/MIDI but I don't see it.
2. How can I save the MIDI profile from a composition?
3. Can MIDI mapping be attached to a particular composition? In my case, whatever I mapped in the last project is what appears..
4. It might be that I tend to use to start with an older composition since I have some settings that are fixed, and then SAVE AS an other name/composition, could it be that when I save as, I also save the MIDI setting for the old composition??
I'm sure there's an easy solution, but sorry I couldn't find it on the forum..
Thanks!!
Saving MIDI settings with multiple devices
tijnisfijn
- Team Resolume
Re: Saving MIDI settings with multiple devices
You can easily make different maps for different set ups and save them. A MIDI map is not automatically saved inside the composition. So every time you want a new/different mapping, select it in the MIDI shortcuts panel
Here are some support articles and resources that provide detailed information on MIDI mapping in Resolume:
Assigning MIDI Shortcuts: This article explains how to control Resolume using a MIDI controller, covering topics like assigning shortcuts, toggle modes, piano mode, and more. https://resolume.com/support/en/midi-sh ... hatgpt.com
Additionally, here's a tutorial video that might be helpful:
If you have further questions or need additional assistance, feel free to ask!
glademaker
Thanks a lot guys, I finally figured it out!!
The thing was I could never see the little toggle with the different presets when in "MIDI shortcut" mode because of the way my screen was split, it was always covered... Duh!
Anyway, has been making my life a ton easier, sorry for the very late reply!!
