Hi all,
I've create a patch where vertical lines are moving when hitting a button.
Now I would like to instance this 32x times in the x position, and this is where I could use some help.
--begin-wire-patch--
2721.3oc6a01iZijD9uRDel1pe+k7MfAjhzs6d5tnreXUzICtYFumwlyXljrQ4+9VcaCX.isGfM5zlgYzLLdpt5pq5odq6luNXQVZpcQQbV5lAu8295fk4Yqf2PFNHaaw5sEC93vAEYvSnzgChS8O4aC2SGqQ5JxCS2jD535QT69emPNAWwV5QTpOmurKyWYiTetzRYWd9IGSoXGk38jBTla+TbZTenbcR3W5jNQu4nnINJ6MGU8c03TGmpgZ1v6jnvhBad5dJY6T53iIkc9ry.YeS7iogIGSZCB5dtR5lToCiD+3i17in87EUyRp3L5zMuhZPyy3CcNSQwmgNgY2lFgxsgKdxFc.hptjLzH0xlkDy4RBG2jAiiaPlaVDbKkh7s1CStnQ53m6N6jmCVfOVMreIOB96290AOlmscMDn4qeCPeYYEkwbRyhrCdKm9Mf4CVYKBcjFts3oLXPCF.50vB6iY4eYvaS2ljLbPjccR1WVYSKdeX9i1BG8ygXCKdpj9zvU.CG7qw4V3ud1luwYS.hVE96NdBK6Uwot24hHAvX2.we6aNNuYQd7ZuMzypn3MNGuetjievlWDuHLYU1yV2zCDDGA+NdYraANfEFY0TiDsbAVi3pHJZNlr.QvDIdoMjHzRXLIwKroaryhSrkyR0CplE3AqBiSJeWFnMiA+jadkR1uRYtU5+aaXRbAnRYTsP5BFrIKYaQ0vexF+3SvrQvZ.27o3nBXbDCECibS3y16nd2KMEOsc07z8K5s4Uu4YvWnDE.DkZ+bwOCXk2EAnE.R5vMNvz.rGvT..u4aKJeTb5lBPvJ+ihur1IWwo.LBrS.aCS.38aEtodd11znM0WzTQ80LLQeFDcb.lq0RIUQLJpTHcNEf5ivzAJLUxjJhVI.FtHIbSoL.x4.kR5oGogWHt0JQZ1bChNmPWtjFRHx40UVDOGxV7egw9L.txb3+rDuRXI7RFhw9G4WfE9IJZad3NKW0ZcYRVXwgUJjPu5KmOFnTagT9vpubjljkstFsyyxRpQ5xvjM1gW3mtguNb6FaswuK1vAV38na3G9Q6R4csCF.zEg4E2v38YGu1ge5jepVFOr5qRhORK+RlIXzOEGAAg.ppg5qrbfN7ovM9H4UNmuOdkMIN04ft2o6+7b7l34tfQtv9.GIWoCEoYGJBVdlCkfSBLTF1HTXFoxYBQBDRB1HIFBGCtXW1chGMWh3BECoCCUHNkIoyWv4FFot6D8Jbm1I1Wx1Q8Yu1dtSD+b6qy5VsxuD6vADb4KB2fg3AD5krpGLi+Knn8vzGS5vN1Pjw4wEP9yiDnyritv79L2nEv5rnMRodR6Uv15IYPgy8u0dpdgVOnEjvYnKEzGOdrq7ELzt3Wi7bqqmgmaepbQFaF7xNOa..n0AFiVJTzZ4BnZVfFriJCiWAquL.dDUgQ7GjXjgPlfFo0iIimB4QLipCfYWA.d9WVWMkWYX6p5sqEQBR8tM2Ri5YzupV5tdFzkI92HfE6v2tgjsNbATQCouYAqnm1O5OxirRAerSRkPeNRsYvXydCCO3eNrQG+O3v.u4mh+rWazhqO89VTjldvKfQK8BXbUfjKLFI1vTG7AjXgFy4bFS3d9k8AFOc5HvGfoQ5oSEH7zwi3SF+.dzzo2ZMQkc.cs.vNi+99R18leYaQqlAZClA.k8oiAce5fPsqs38QfKo5v5v8qCTuNOag0U+W0H5Yf3Z6jRGSPUjxlAEB84EJqjP8vJ..HjReN7xxjkbn.Z.4.QywJcqQFwVQHhOeYDZNgIQV9Ro9exVrfKY2ZjwSQE0Te8KtT8sfpkzItz+eb3E94Yvq8l4FLLC2gOZBE9SYO2dA.T1ObvOU.jAlgEDkviy7vOtwDfI.zSvTDb6AkdE9c+feh6aRnFL3HpgFnfLNBCVSOzJA2UgFVCImzBlfHZsYBoIhi3gFBRGwsHJIjwoKLgDJ4tjGBeeatqVZn8LqEif7kFCv9raus1EB.2gK5tEzKI.f6g4qyNCI22NJqWMxNf.gIBHZNlhOpfDoTFnkFATxdWkivg5QPbMaFxLipQjwiDynDhg8v35v.92aXfuTQ60uUFEwqr8aqHNAvU2HcLZn03BOXcabSqXR0OJXRd.Uh0RNsV1HJmFvfzQJiVSauVnWgjeufj2TkR2m9ppPMLJ.ZXfMtLdU01LaBDZBQIqJq4xPlopoyPbCmizylPQOnwPyUXnYrIiu6IyN0tgnCq8ciakPeM0sXLmsqdmVrl2ZguXTD.QS2Tdx3cE4nGgjJW260H8j8jCCnmruHKw5NSFaa63HFxQ5eAnFtlJzufPZPQUARCfAw.bzclGU0aIBTJdsczsk19GIffZxIt2MSh.joPBw0FOiyu08tsSD5Q66dWfSVCkJuOZScyRsXOmhcZxfW2Jc.VO0clbsip4+0soN6ruBtJPq4RNSHfhnUGJmVKf94g.Kct07yMgnP0RIxPoQFoTKVJWbqwdNb35uf80zo21sslcVL86V1txWbKgTVjrMxhVE94KJ9USCPRec0WEm1WRqtqF8k7Mw+g8NgmfLW3.lQgM75maJfiBftxTx9TEzHtdLhOZlAoMJHCGCKYiwL0C7I2ZK4GaQNw+mWpjaIR5onpCl4ZlmZF0SrD6ia3U3Gfh+i3TaX6s0wjWcrfc28lNPCd3Y+MzP0IABxo055BbPobNURglvZOuPjTfg1vililaEtqNAdod4bNX1r2ZdgJWwq+HQ1Ud6cnQ95J+lKv4emFtdySYsu0xrF5gJxtLbaRwGbBTGVWmf4b0umscsCq02ZhI8eadft6UARHPgjvn6QWLn4dnXCrQwIzN2XuQDBhO0HPFglCuaxTrBqGqY2+xNNao1ZoDma1ZsYlMPcDYcDcvb0Gg+96IFpmPCemf8kX+8h.027laJrq6MwUNj8SR58Y8hHZATZqr91I6RoY3FM0Pvcr0hSdPOAfZRIRKwLDz1O4AtjZvxI2JnqyNvct3ceUTvU54KSAoew+7S2Qn7irHGATNBHT2NeB5qYGfItCbsis8jiussX5k1fVuKZCJEn+r9EVM3Kfw8s1wly+yBDFHitRgwjxz5M33Hzp.ljnI0NHPe0fZCUSqt4DW10Y1C7QHNmMFp5CZSTMa1nwSvpoOLZ789zgOsuOUkt+dVZXsiYo4JCq2B4wcKdho8LPzAOieMObc6tEjW6hYuYldAzMwckrDP+uDigVtEGmcrSDCAJ8fKkJy9tjMvyHTNlx3sVIxq8yz.vjdCwqu9ZMO5dsfqrsXNAx3y3TkxaIK6jgnCXBpAL2TIoia6qURVh3zEXHsOMDgiVDh4VBWHM28a1R24gqeuP8JwyNAw27tzVsNh+5uh0PihRP+fkFCTfj1rOkgfxgrMFJmUkH4uAWxZDeXsue8lV+i5MsV983lViCfDRTHzE8PpJlgEXnXpV6tjDser3udUq69pVq++5iOTPEAbkRoYzNNalWO8PGi1F6OxAX.49OMZ9pB3RUfgHK63u7yqfzcrrDPyhE3psG3Oxbe33vABAliIZojyjXLW5p8ZiMo7CaqSD4NYf6zRL0.+N13O1R+AM32dW+483uDU9Kwi+VSLbfa.tm378bT69G5A9B68W2T+k9ye0+8WBXPu7mvbyidR
--end-wire-patch--
Instances
Re: Instances
You're already moving the lines on the x axis, so not sure what you'd like to do. If you add Transform after Move, and instance something going into that transform, that can add instances to the rectangles.
The left part of the patch where you make the triggers go to the next channel could be replaced by a single Circulate node
JonasVorwerk
Re: Instances
Thanks Zoltan, circulate is a great suggestion
1886.3oc6Zk0aiajD9uR.eVMQee327gLPdXSVrH6tODXrnEYKItKEoVd3YlLv+2S0MkkoLon7glfIHVxPhhtppOpu9qptZ90njxhBWRSVYQczE+5WiVVUtAtfLKprsYaaSzcyhZJg6PoyhxJB24gY6kiMpbMU1h5bq2pGHsdnzriKsbToG1Gn6EDuWRwrnJ2mxJROTR0PIwiJIdPa+XSiOPNw.4ziJGXOWQJpxYSV6ReZ.oNlUGUZ4nR6mweVmfOdufxNtjjCjjqGNSwMiM6yG15R7XBJGNmNtWZbA2la+xoDC+RsGdu8taWW8mqRcUQW70nUUksag0Be8AvXkkMcKKJJScQWvoO.FNZiqw5E011rtDTJJZVThswspr5KQWTzlmOKJ0sMu7KabEM+hsZkqwK+B.nmrtS9B6FvfQ+6rJG7q6cU0d3OHzF6+0aS.XrIqvek28t013UD+vCdKWmTksMrbIXpzrZ+f4m5r3+xU0jkXy2Tduy27f.Yov2YKy7CvHlM0ooFIZYBVi3pTJZAljfHXhDuzYIBsDzIOKwUT6tMK200J6twtVAtwFaVd2UkUYqxJr4u6QJY+Hk4Go++VadVCLkxnZgz6aqKyaa1o9ZW1p0PqQvZvc9orzFPOhghAMqs26Niy6gdSy51MKJ1Onaq1cw8vR0NT.HTg6yM+DfU9wznKjvvwia7foHb.vzzTksnso6VYE0MPGq6GMeYquekU.vHvOAl0l257iNeaunrsHst+nlJ5Ong0GeF563XLWqkRphXTToPRg+AL+QX5XElJYREQqDfASxs0ccBniFoTxf7HM7BwcNIRyVXPzED5xkTKgHWze1hDrPYx+Cz8d.cU5W.TlGlEVBujVLNbqvHrIzPosU1Gcc6FrKyKsMOMTgfNCd6WtAyuSnDe1f2dkxKK21SqEkk48TZoMu1M6M8o23ass0tdVG7pqNvq8qARfWyGAy5ojN6VEV0zXqZ9VX3.U6Y2tOu69bONd1f2cpcfG+rzY.ytNKEnOA06sdcG7B7Xqs.P3t8zJ+R1FWdVgmZYOcw+49r5rEdZzlpVGXQxakJXbl.BVNfIPvIwFJCaDJLiriE.QhERB1HIFBGCbCGmGfmtPh3BECosVEhSYR5hDN2vH84AnuAdfG61Gy8RCwcaGtlmODB3c66F4Gyb3XBt6Egav.QFgdLu5Stw+AjQrsXU9z9QJcniDZ8OcXm4SO0WhpyVAgI8wIB4bf5j5IHq+qmjdaUYhySatSiWVzhCxm9DsPXthFMNtRnGFfQIg3HJgFKjx.DpK7hjCAdHLJDIFqzjoPVXmvh3KVlhVPXRjiuTp+6rjDtj0GYwdCHqtTNeZv1a96cxH0eGJOCoQ6YaOr7tYuoOGP0rGdLh+b1i3pwvt+MHuuogsr+5AaUw.A.CKHJQ.eFfsbiIFS.Hqfo.ZQl5CX62yvV4qE15t2u8mGQs3S.pdLegWEl0e2pskClieowt0zAfUDgIhIZNlhMFY.VFPqRoLVKMBrTyDSCV4WMeNhqY2hL2R0HxUWJtkRHF1MW0GrxeqfU72jjTceCRQsIai60lI4yPz8cvGBklDOeiymL+j.Z0eY.z7XpDqkbZO1WJmFy.5WkQqoSmyvG34+LfmeWoU7NpDxHPNFEPbL.fzwTtqFHlXglPTxc4.bb71b07aQbCmiz2dMEciFqmOGyYrqu58VEjA3sm6BQzYG+u6dXewZeOffIby29XxAG2OyouCdq291b66lY3NlEEVGS3Jrg2uZWboIlwEDJiZHXhXxc55jjkv9aSvHsjZQ3zDKl6HbgzbV70SwA3WUe7RLDlD6UZgNs+gerXZuidrpKDVjmBjGE0cmzyICC3AYuFM1DJP9wEJTU1reaRYnu7BbPvBULgRIFJqK7Qv0yHLXmnTlPyLZ9jIIkJIFvwuXIZgjjh3IFqJMIUlPsu2RbLXQ94Kk9Aq9OeltdSYYy5rhUSTLkCQqAe9N25rQPYigidBP+OK5BAMAV1blKZ9AbHzNfDiahgbQTFkVP1yg3ARbNVAr97c0P63PIH8jKQ7aXZDDm.1q37qtje8U2fub97yNGh6yMsUNZ52j5Z1isoqc9getsYRWj3Ofi0Ppik.eLVZLbIUa1W2IADlWXLTNiHOQAM+S3Aaf3yN9eebDGebDGeGeDGx+HNhCLjiOrkRpgZj5cY4yLrXCES0PN6mpJIebFGm9LNjibt0Esatdssnvk+BJp6KqDEiWIWULyefBJvwfkXAWpGVaWjfwikJHTM8YaAfqLXLyLcbALUBwEDTJ55aLDjRvLxqwjKmeE8rjE3IS++ETpfgaSnSkYONclzVUA6vBATUtO2yEecVURKrU+ocw5uu22tfJ.WoRoYzSjF1Gaa+3tYvPsY9VOATnJ7zK4W7XDhXgRIHbIOreocGTLWBatBCqK1yiNK52J8OMU3X+yWhAx5RAruRtQJ8Alb4cODg99oe1iph7UDxeX29nAAhjPoC7oLFN5zvAQ4QegR6G13ZHieXP+6viLTiM
--end-wire-patch--
What I'm trying to do is to have 32 instances of this. So when I play 1 note, the line at position 32 will popup, and make the animation as in patch above.
When 10 notes are triggered, 10 of these animations should play though each other.
--end-wire-patch--
JonasVorwerk
Re: Instances
Here a version with copies of what I would like to instance 32x times, see included patch.
Any suggestion would be appreciated
5960.3oc6ck0jaiij9uhi5YQDHSb2uUmQzOL8rwL8N6CczwFrjX4R6nRpFc31t6v+22DfTRThfhjkjqSV1VVkTBPPl2.eHwec1vYSmlMb43YSWb1O8a+0Y2Me1CzafAmMa0xGWs7reevYKmQeBhCNa7zvm78AanSDktkySmtXRpuW2gZaUpE0SsNJ0UGC7JzslL9NzopPmMJc96f8HTVCkh5oD18do5fjFNyy9iwSG0BBebR52ZhLda6Odr9qJCWGkgqkwFeiVMOB+SF6RGmTW0KO8f7gzkYyGmNYGZMUenarwFpFYTBqSbyXpRt6.jqiRdjgQUwI+HKh3jopDpePEixpZRVdbJc0S4thn1ph.l3xn0PYEgpXzgstGwX8HF8JGUlJFsXcxe9K13kCue6CIczGm1Mbc9VRIdDYFcz3pCAiW9YU1FRcb+GL9yeNa9ND53U6VMOlzjCpRoCqa.3v8G.hZF.hH2WPTC.UdT4fnOpbUU+jQUPrQt1NYbyn1CPJtauF4QpSE8QpJx8NMlVbe5iY6PoL1kWGsOiHm3G7U6SWUUYfG0OmyEmx5rPAbLRCjGpAP7FDYrT0XoyEUL.37HcJVCshHzppgV4AnE1iVcDZi6vrVZqXLJFk9mKsrS8jFoOMwu5QMaEiZe2FmXHhFA.Pc1NBe0NFO..ia8H7EU5ZdTMi.Op5vHpDe3iq1uQ0ipZWJbCGUx4PVQD6MBp5SFPd7AqNNo0ptAQTnQ3PMvFuAwFLQzNf39z.HhLGTi1LFQaFqQaFgCP6dZnQBkNLthoLUGsU0lhRorC8pLZuJie8iq1EkZYsTahHwi1ZURQ69JonqFkTzEqqiq3gwTnEwk6EwrqfpXJogOtVUOYSJzX7ngAQDGcBS7AqHNo0pyIhnUKrGpAp3MH1fIhBhPTy8XDwHQMJzhHJzhZTnE1CP6dJoxHJ+hZTmpi1ppSQoD5PuBQ6UH90OtZWTpgZoVFQhWppUI0+U6pjJ00njJ0w55ZT7hoPKiK2KiYWQhszSpLdBqgNnV0YUSo36CxNZJ95XQ5Z6.wdyLslX+MQIh+8hg+ee9Hh47S+0Yed9rUOtfd22IYxYyVlOQYSmMJ6reRC9Nu38xRu2s88Vb66oH1J8KXoVPhfemFom8P1xT+UMc0x6mQW+yNiDqnQ2mmM+azusX1p4CynOaT1iSl8sGxlt7WSm+4rk91bKYShXag1LM8ApWO6+Y7bO0eIa9BuXIQzCo+e99kjGdX7T+6715eL0yu+I92+tumWLb93GChwgtZz3Ed8qeIuG+WYyWNdX5jGl8kL+kmHX7H5+Ge2X+yqyDoixrnSmb2PtMQZFgI2xggIT1EZ9cYofxpo1LY7vroKxtY7jr7qRwGTbUNyySFOI+cyHMkwSSmbz2ovl6Tg+N8+rJcx3kziUAZUZuEmEylrZYQyuOa7mueomm4yk7OFOZI0NvgbpkKR+R1I74dXzr79UOb6zM2zqlW7lujMcTtj.Qzzrut7WHAledjWjgzI7ROdgyy3AolkjUkaWsL+iFOcwRZjk+KK+1i9A13ojrDwnn9McBYR5mT9q8syVMczhx20np7MMoO8UZryYbo0p0nAbFTqzdEM54G4EgY3nVnMf0nnNb3jzE4iAZfdlwnCzmXoeRjYY5Dq3VWBdKf2cGlRglda4mVPnGlM7eSs8Kjz0LuRvrIgmB2Q+nS47vGEtAWFtPaLUu8d8tIyRWt8N82fAE+wqnQOUO.oxAE+wS5jYydrDs2Na1jRjdW5jEYCp4UeyeLc0hrRsesg+scwzUSlLHxKgV6cs8TaLIQuLc9xin8AevO0lu+Ee+mx7AE+Im3cdJ2kqD056GOhrBQTURpufyQOCuOcQv6ag14uN9grIim50P2n08+9kwKFeq2Zj2UM0ivSTgBhqPExGdOEJkDXNTvcJCW.EJSI.SoAtSCNxyOohUu5jbzs5DoxHRroolDIJz3sCkRm.JqNgOA0o0C653cXva3ppJQxp7WO2s3Nuttiy.d9OfzwI6A.VGWcKa7ejMj9rOOoA9H+zaZjIkJKmarAl1dbUmf95xlGQjqXJj6bZtS7tv9XhbPo+1aj7CqQR9I2LohQlCsBTHzRTEWESoULtPQZK4QbjqlwMRlUhbIMpT8FNOdCmXUdKc4+icGM+w1AyYKF+YJNcefpGiAVKvrFsh7XhzcTACdOI.gzQR.BkyYUBET1VqlIbNYS9Nu1b8MIRmTlXu4RL4JK2d80boPb4EGqo1hTkOf0SbPo+96eeyzszJq.6vdKX.w3x236BrAVr3XXwzXNImpsVj7+2Vpeb9rgYdWOcQnXmYWqgKvc42jwEjTFlwo.xDhQVHPTMoFRZSwcHnEbqx6dNOkFiiybZAHjF8gMlvyToIxauaTxsfPmjIuSa+uDCGJ0hxRRhmpjToa9RONamykxSS4dBWXotvKd86Cp40JtN1v1ivnFbHIx+1ruzjIG4Gc4QKmr9wAmj6HYP8FmazuvbBmdch28xiOKxipXg23MumLhhOZ5hbjycXombi6cnAODlRv5oILETi+yCRCdLwWQ5gReloNEIIp1jZJ3bHYTTB.HPeCqWHbDk9JEW0s2kbqFFkHG5RMiFNRODSO1Hrp3dsyRgU7114dXwCyls79wS+7AhLaWwz.OsfsMHhLTLwjsRp+2S8OtNrnptpn5zUOb48oSmlMoYSbMaV6HrpkH.meZMTnPJ1DutyxLZojKwfgtCXRC0TdwJDSt7JGjXTjgvK4v4WeAdRjlpmKB4IHlcvzC8RE6xsyaxf0OFGtZ97roKSn7Dy9ZI15kimObEYtpIqPlmtWQJqtjGR+ZsolWbMBjMdZSj0xT67yd+WOvCUuArcuZUTdFb1rvZPrHYHIwsrIygqlNtQZHYxOm0.UwSHA2JP6Wtau.MPwG5En4VvXM.eSjinvHXXqDquBETtnmqOO4BsFHo7yu3Zk5RCdyMmZO0UDqqc5.JjjVKPjyn1JGkyZ2m6r4gaAmXqH9UEy6zmDMHiaqJiS2LiSmPTN8yjYw44.UuIt7siWNJ6wcxYNJcqWyuV5WN2PvnUCypUGILYVeu75Hkjda3sYGJXG+ZJMvuJS+9tssMQATh74Y93d9xguT4ysWXQeac7HO4bzAkBXZtfilsV8AmQxPTnaJBhqOG0IRyU5DJEeRCQdk5pKEf7haLkUNjOAkiB4pzEGzAdnmIg34oknI+CvQaI6unKa1eDd3tNI8nuiTI7D93r7Y6KXfLvPJLE9aIvfDh878Rxlkuvg6oxrRNyXsjEDAWaDNK2.B5yP5cBG8TlRo0nPmnDK+oGwyNVKhqVNX2GqQjxhqyUUlOtXcb8pR56azO2Z74e5GBe5ejMcTPj9.le.dWcwl8E+pe+8AcKe.XaCNbDWqaYWye.11fVeAVNaRleMryNz7Lx4t7eHMToEU1mtggDJ+BAyQzHkayt.84lvUV5+jG1u4EmqtNQpuz+tazIBwkJ84pat3For8gChiFB1zFStnxCXIDKChJjIrQRSkuNozxbnRon1ljBJyt1JoesGLCMHhehmp9VwoIa7Lj7.XUOQds7VWZRp4NxM.hibZsUcmd3wNEsaQp0gcl23To+y20vCc7I+PePQT7IO8TyZEKh3LLkA4jNc4j8aOKZjVwSjoitM41LkGtO76r2cqjdtmcrYmUjGyASOac5XcJAsxOZiO4P+yooOt39YKaf+JhE15v6mMukST3fWCyu47YKa8ja563ECSmj0VhOQSdJk4EyGYi1Ifsyiv9gbhNCijgMBKZ2HIy4FlzRYn4r1Fh5jLxP1bHecItqvqRT2Xc1qcxKuTHNVWK4hEGwzdN33m+00L5VudydFcagLPamb2DfhRM7CwFAMZkfMba9i+K53bGuqdwNx8C1QM+fSy7u5636lM+gFLkHOw3TwuDoZPooLADaVn78Aqhh4LBkALlRIo4SXiQ9BzMNOu8H5qGrJuY.qBnN8fUgiJGYdAcJxSQTeRJsgYkj9kUfag4G0LISaaARE5AqRa.qBnew.qBmBv.MftT5r6iVEEcqqzZo1PYBUBsJjoWFIVf9UznGuJMiWEv7R3izmezVMW5MblUwExhEnuGOm8tHe23hz9x3hTS1GoLzT4y0PtwQmirZZ1nW16g7H8P5dC5gjHFXzGYTtlvgWuGROWF4uyQPGoYvcj1AncjS6X9qMVjoofpzBvJ1BoSzv0LzgRKugIzrGAcmNDzgvGd4QKGYjXmyZLNbKjN866KFpcs.9S8ximN4Q7cHhNaNBKfr4wn+4bFdobYPG2R1DExhDb5Az4qG.chhWN.c1rQsDx4JSJrEaOhBKZfj0vVb7CNTNQYOTNe0AkSqKHIqoOQTFJmBzZYpCKO+gBCmxFDtU8X37sEFNaNwbPoPJAbM2Hwsa0VKoxPegyTjqdOLN6gw4qAXbhldXbdpfwYy1F733jLNrcx4JhBD4Lg0HUEPN6MNPNcu1.xIZO4.4rE7ZK.LfaPhypKASvNvseiCkSz8BCkyVvjTZewmwwE6B21Nvj9HClSAuGLmOSf4D8kuCJwKtU6pYOiRzXYZkzrChIHSGLKX0bQSQd1CkymEnbVrfkjeAIXUFGrF+k+f+hWyP4T.mXXpn7XEyXQtbyT0FCJmf0RV80Fo.zEJUdq+J.8HXYcEKqGMm8PU4c.TUD3oFpJFFk.tzPwNo2VeSiflSRyRaEq2XL45XBCxDTx6n00CmyiGrJBwKDXUPOz9P5u0VKK7kdLgAJUPGWakMD6sT2nHPORUBrX4KgSRAyGOoSVpTJky9nnCYRset1vdTc16p78kqR0KiqREYnjhYmKJuyGDFxEpwRwwmuhB8tJORWk52btJsN5ykJmrwhYWuqx.K17tFDcVleBJQKIKv4JeU3zFsNcRFb.cohhnPZELG2o0ldDz8rgfNg8CuvnGQm.4.zso.JFrpQo.ZsZTziu3mQoQ26N7b1lXq.tzCdXfBtxVN1JsUUtv5zimyWO34TxeovyYaLoEpPm95xFGQmzsEqOBiCXEnhqGVm0wagdXc9ZrBcRBz6WaKnLUzLrI44OTv5T0fvM1Cqy2Rv5r47xCUly8Kw7BJMJFX3fVy6A0YOnNe0.pSorGTmmFPc1rkg7RyoxrohjrNFPKcQn7Sabu3+V.RmR9qMHcJOwSPea3zd.cZcnPHVumA6Fm9MNbNk5WT3b1BFjuvbhBIryASTGXPejgxozzCkymq5xoOTRME2HW5JJsBwqKmVsaM1HJDk4blT3wyGuGKmu7X4jStCxihPCJKk1G2kC.ye3ewqXrbh366U6n5BsozLC2nrbe43YixJ.9S+aPfs.Fo8quwIa8Mv22GPiQD+LFJ7FtfqnTj2t3ZRmiwARzSIZdtn6E+NUheuXnvrJTRPevvfSTphNABGibh.FcgnRONRNH2TZe2sVo5HqLJxY.h.kZaoh.u.Px+EJT1hzc6WZzWMKMpzcpm8iRqFDFjJPkGJZqqm4AIBK4oQozJvpZ7.m45qOOQdkvlPVMHGLWew4xKu3J94We8Iw5QY2mYec4p4YkmE6pYIGMb17F9o+9pCmZr5Ti5ZdEUPskokJMW61hF9vibEYDW4b3l8mTOHq6AY86DPVqO0PrtpqMkj6mPPbydTH2ylSvbd3cXKlmvd.UeT.pV+xgSmHnxQJI2V9cJ8taWEI3OTAPMkNtr.Z08fyoF9IbDKe3IJHj0PRQ5nnPQRhsz4frDzLJnTth27VORgFRK9hK3INC8xUTfI2bEo0S+1oNPjGFOZb6hAoHEyRoU9yW8ye5mObLe5i4fQa5r4OjNY2bFhhFp+La9rjwKRlc2cGlz1lFZBPrHxbqSfP4HaBLQRUTZMMB+Wk9hKSjFPkb94Wcdh6FOt1sNm9b74lIt8A4fcXnketQWhbSe6XIMczm9kYKovMafM2WuCe0ALNDTAeJpcf+ilLMQwVP4CIZZgE+HANtCKc2enU+1BYbQPBmvv1YCCG1J2HSZrj25FObl5QBWOR3d1PBm9G8I3AzUeWmR+RH.VV0czBn4LsQxMXS6UT4ktqSj2PQHeg7FdhRBpKHwsqOGt3T6VJpbNXzR+JmpIgciFLd4bfRNyXEbtzDJgpd47lbgUiKpR483u5MEfsAO0Szmj4DNQokfKx9hiI4fYWHk4HqoZmVqTXNL76q+P8y22a+46yHN80TAIoWYPEow.xZNorHkIznHEQ2FbC5WKCfhXQ3KNdTf8Mbjs1OIfsXR.MxWpU9lYQrHpn0Sx69KEtPxTVokaExxkUAmxib60Gh68qE9gYvpme2iFKy42YuR.KcJC.BQ3TF.0MUaV6WSrdejus7QpeY7QxI6iFhrcpVH.Rs1ARJSTc+Qt7IvEo4smKRxVqi4mscNzCYrV4l78dwdAERqdMpf12ecnVexkaNxHyCyBkLtPQRRhFANTOTTOYPQ039HKIZMLRja6LRWXMCDLxntq4RNZuf3ISPz9pFSzJTQN3LFaQIWr2+1gYl72gkOplCQF3BNIln3kO3d..0jmMsX8A7RODoe0.QZK7xU7nNjioDej1bRbZeWSjcIlUn0qO.Q6QmVMLVrGfLu5.Hi+HUF3niRtb8rxkKUq3ZlnUR0enJfTM3iUziRl2X0Opllek.rY.kDL6jZL3i9X6oPdOrY5gMyq.XyX0GA.v6qeT6XYvChCEoBK.65jNqVAoTJOfOT6T0+8.jV4LBEvart++l3XAU+JqFRYMm7RHUKX1V+jgBZn7FqrfUuYUNeuVBob7W3JHUK3OJCEv51JrSmUE+.WCobPuaimW2FVRT0IcFdIrXCnvxnLyZtre7lvqg4UlWCG9x30PyzFG2X1LAkkX09kYuwUn+ssmCwaAOGN+INs0HKuYEau53GYOGQ.OXam6h7Utpw4ESfcYF6dkOsEwWHCk14OyxcBWMm149S6Vl0oMX4SHZxlBSQxlBqvzzphdNZHYzqz7DG.Wlbt0dAbw0Zg1c9wNIc29sGKtjGbBkp3xnt5+wZR4cf1tzuXGnUzAZkcfVUGnU2AZMcfVaGn00dZ6viWrCrXrCrXrKigNvhwNvhwNvhwNvhwNvhwNvhwNvh6viLQGXwhNvhEcfE2AtVGXZcfm0AVVG3Xsig0jmLHemvkNb7xuAGNPi0TwOTlRpRDBskPrsDJZKgx1RnpsDpaKgl1RnssD5ZIgXq3eXa4eXa4eXa4eXa4eXa4eXa4eXa4eXa4eXa4eXa4ehVw+Dsk+IZK+SzV9mrUCPUqnR2JpLshp1xIZfQrSFREg0tadJCNq5R6bbK1SrTu9W9Hu+zea7WaX4dbp9R+9yXoeGUnzTtXaVozuaELN8kaNvmKVpXIIboAsToZpdR2W82eFp96TVy4kn8Feyq3p0tS2q6+bo6yYdrHncB.Tqmgvp59Hi9xcNmbQDXbmrUEDfdM+mEMeS9VDSZzV+w0tEWqt+C9KdMaI4otb50WmbYRoZ8gmPEUEmzef.o1q1.BVvwznTXcZosu3Yzuwfeerwfc1S8FCVwbJ+ldQHzxMda1eiAq0LCEsp.jqWRAuNl13KM3bkqnFf0uufOp8Er6GcUppNbqBLqQq.tFoanBPau+NlR5nnVDJmypDkVzHvhT1Hsn.r1uoo7czpwgUKeC9YKpssDCPs2lk0eZ0AjNWoG2+4rYO3E.k9S.Jg2iGoG4g3p2NU1j0PA+27GK.4mja4mAn4mDw4G114Gm5zqh.MBa30.kBc3UU30PqBwJBhPaCJpTrq9WwPawPawPawPqvPqvPqvPqvPqf.kPfRHbUf.8PfdHPODnGxoObU3gVwCsh6aU9uGZI22xPOwCslGZ2YA6iATBD.nQ.JRA3lEP4W.PqAT0G18Hg8FTXirE1irgsrcnxKDJQQgJvZnPU5GP9uNbGoyu08sIbe57D478s+ibgAmz+pLzYgapfDaf3vHVFtBg1E5LtmHeSzgQR3c9Al1+4FyYjD3+Oniga3I
--end-wire-patch--
--end-wire-patch--
tijnisfijn
- Team Resolume
Re: Instances
I took a look at your patch and I think a different approach would be easier. To have a look at this patch and see if this will help you.
I first make the 35 different lines and repeat them 3 times. Than set up 35 notes to send out zero or one. then I let those notes control the alpha of the lines and the counter for the line movement.
8348.3oc68s0biajjt+U3x4g8EAL08K8a7Zu9DG6YiY7YmMBOc3.hDRM2ghTKuzt6wg+uexBjhn.SPfTMkTKYS21vrISjUgpx5qxqE90tSVtXQ9jMyVtXc228S+Z2aVs7N3C7q5tb6l62to6Gtp6lkv2Hup6s4KuKeypuz8C+1UGnT8.krCjpup6rEE2aDct533cYaxWMKadEJE0vRg+ptqymuqmVkZfwYquG9kUYvOVdGp88BFMx80StG0sE55orldsj8n60l5YtodlWPJuBogu93drsdlZqgo7ZIUxwjBe0Gymc6GqNMGFcPLUTOSE0PprdRk0PZ8SvRUsc0eY1zMerJgZrDop9gz5F8g++prEquY4p6xPSuRXn89rMfv8hx6vUe+EKgEt60y9W4sRmr9taMCVJV8h.0LaopWDPwZfzpc.UMRKp5kAT0IC.O92MaQqrrftrOWkNIZTRUKbTcDZpivZF2U9ZleBe4wS455GJ03kn55GI00MRBcy6msYxGamRccTF91OkOe4jYa9RY6KBHUa9wUaO5oxbZhGmMecUp0JzCV.ma904SWVkvZVQoqe8bIobLo7SPp.SpnsYUccq5z0rPVW+BYs.yRW88SWCO8x1Is9sppepBncUNLYU8oGuYrgQT32TuLsoF4OyA47Dz.qAuFH.yVfoNuF.0Z3tntdroF.EXn8t70GsdwWCGqeyGScMNvyIeLCzcZ9QDWyDlQWuXfuARYsSZ8pJXzM1aq1ELlFIt5ZFCd0sodQQSMhMhSO4ZrHxs0uekk0v3.ucROwJ2ZFxrf77jkyWtpcJE0QY39OF3vVu7UfAmjzidnv6ZoqcWKKV4Fc8hVV7rZnUpWsUqASLz6g40ayakPdIgeXeW4urZZ9ptu6W6d6pkauGr.4W+MfnkK2ryXjEKml28cZVfw69rzG8Yc4mUxxOarke1ph9bD8VyuAcW.VXSVn4y1t4ivD3651ElKAaRtcIXky65td41USxguaZ98yW9k6xWr4GyVcKflB2y0vCCr0565tcw+bwxeYAP1hr6.d28uOaU3l9T9p0gAPf16x9eBremhMgOI1MmGte1u8agFX8jUytuX.+cc6045r0ylzQLrSAQc1rrCzpc9xxsctc4rE2lF5SyVe+7ru7C6Zyue1zYc9+NaQ9pNW+kN+3r+mP+Y1TnGO6lYgw3tdEapZpYRxM1qsIJyTcRlU6StQvuwHTWO0jwf6Y9rI4KVmOd177ciG6+h8sS2fNWylu6SKWM61YKxl+DMnv4UGT9e2lMOrY16jBWPLG1Ha47sa1e66M93cbli8f98ui6EfzR20YeJulN0W6TjLza17ws2c8hCO6aWs+CeJewzcxN.QKx+7le.jv9tocemCVYEj1Bh0c4EhYa1rZ10a2r6qlrbELc8yUep17k6C8uYK.gPXZCXe17sAg8eKrjY8F3IY2ceJB4g950K2tX553QImHZLBPB9bX3lwRkRtm44VuwEvLfA6DAWl58dgzxLLsJ7C.KmLOacAGmAOZcsVi2JL5jQ9ApDuP0Oo+HiHYrZbe4XwX4fQ93wWdAGVN4eB26m.wxkce.z7ccuA9GP1iU7UEOhapL9jMc113G4aluLaip7I9mXWU7mvB5GdbqRbIsBflseJlaWu7yhokD7qElTDLYj+gclgTv+ODFU2O9cJdWLx+wYSgEcvMUyza7L3ttwUG8P9gCBn+U.8E.KmGjROH48yeZ15YWGVXtATTGZMgBKVA8peoZm7WJ6ifFt2BKX69aOrWPxzY.r15c9+oIopC2vNRNPZw+qj+6FSdfZ9ik8bZrudQbUpvXUblv5jBljGrt8HY9DgTXRcLtUacEDDj3geMky7Zsi2p.urmPknFM1kzSoGkza739Jo1MzNX74Jvue24SJfwNLJQVHLdNq5P7UOHYfkCpaxqTx78qxCdsqY4RMVtbZ9MYamu4+JzOaYVdw14EhnORQYxRle8vnZepUKEZqUyUFkSIs0Hjwc7ySHajeDOQ0u2fDuUIRfuZjVvr83LYrPlnQgLAah85qe7BYMH.gmCiDidXTsTToWgGN6T3hyN+8lkXLuRQxpULPxRMJgwajNlgqERUvj5ZwZLZ4AvnBw.dpy5fcbMfBY6130cZAg.6Ac0riS5CRZIC6yjiGOVOZnh87i1zffvIwNJm74c9G+4Net4Ic6EXhikOLpcxGRm0K8Jc3W9iEPw+QyxLNjLSsSAboLU30VIS6YtSpN.fFeVH04SLf5.parIWqTljo4hLl.FP0W6hm.XMNALkMgysGMADO5VNR8eVXO32s3lkMOJ4OG3TRB9Q9HnkkTWubYAietUsiYOu4Riy6ST87CRbhd8S7JukaXRopJXq3alpcwtkI1BFX38.UEB.UVYdzzzUcae836AM7ZT9RhEunI1vz0OCyYFrApZOO0.SML.aiGYeJX1JynfkLJI2nXllPHycS3vlt4SRb2jmkvDJQ1DtfwXhycGzCwCu7A9guJ1jxeJrO0UWtb4BbovqiOj0CkxMG9pRole8A4ufuHtZm+H1S8Ol+4MaWkOsavglWn5BUWn5BUWn5BUWn5BUWn5BUWn5BUWn5BUWn5Ilpf46Gk22QNzrxObwEPWtbBW.cTfSv9e86yW+wNhgM6BV1ePcw+4EwrugN4mSvI+rWSN4m+RGS9GS9BUjR4MPiXu3HiPrdCeO+YTtkqMmqbaO1PWhR36kzSqcIFe+AZ2P1PkP+bmI.TjaEUEG2KWTLG8vzP8oZztg9lS4nue67Myte9WZVZUbQZ8ITZ8bBj5EY01jUkWjUeZjUsLWJfqxNHUtOFwRSpz3UVij6jZurIwU1PsNQ4ziRbb4PfklgC0CGOx4F9ZPbUpeNkWGNK7rzrzp5hz5SizJnjYJWZsZiDDM0lG.WkV36Y7Gxyg2rHq7u8Hq5udY0OlsNoH6+aRq68jMaQajQ1FqpMYMi5UarZLXXYQgCsNYBHUtoolKP71EyZkFPtcesybZpZsLSBmDA6fnsoRGS4eHYc1KyabodC2.p9x.I5l0nXnPBPz8L8R5aL7DFX51HsdfULtRV2K+Zk6aX7MUo3dufERjSPEdFWeJ62OXs0CRH6l5JEr1MWe770gg68yMkR7g54pyeuX3rQYdyysm.NcVa4RAcD0VlRpfq0h5cp5LR4nWlQRioeRnERbRYujg9wJvjcttu6rq5hUK2bri7NRD3gBL52O+I3Fy0Sxlme7CsH5odWMPc45kqufWO3f840tnrh7YPP9pKWub8E75GpUC25bu5OVIZPs5Me64rG9j4amlSQ2UfDp0+Bn5BUR2e5EPk71rXSdNZaH0lTPGA+9Zt4wpnQOkCTzn2Xehya0IijLirOSZGpFbtJZdt54ejVmky4QyUQyvGMsrW4zpJWl0bYbJcOyJVdpYZJFSaBUR2W+D8H6nwIJuRk3FOPjLzwbiFABVxA8etsj9mdxzgqM6wepZIpXdieXO5FjodzUlzAZoXi9MgCkpGiQ5UM9qNIzGio7yVzFIutsUmCqbR0Bg1IYrHu+C1pqMvOpMVoS3ZLRUBixmnxt95jqktaRT4f8eZtKXt1YFg0ud6toZw8OBFCNuyOrDDL+G+4.B45FElqwwnYYs4LxqmsYZ98UNIIpchEZnESms311nKb1VQ0eorv7V4QRQR10EerQ6.CmoJWENkU9P068thSRml6aQjuJOnR+mZto.K.He9kH3RS5QNRUvXoVlyDJs1VJLrQtQCRr83uOwy38RFLdz.tUMT12XoW4lm3jKADlVEKGr6KpdNi7oY4+Rwi7C3r09IPzLP38KWso9CmjD9UIgAs8BBw0TD7WujDRWtPIIj.TKLPBd0d8KnqGQIBnqDeULryeEP0Z43CQwtDvomn.NAlLwMFF+.Do1lxfs1MBB4bxq7.iJ9FGWT0k7i5IKiSjGIlpnKkJTA8MGLPlze3fQI8GMVnYNotmv7Z3DYh8bJk921d8lUYS1zrbp32cmsNb1wF++HDX3BuIAZBUROixjnGLR1ejV3EtW.Aly6P04Gxussr1T8nysn7Oku3rOxap0ZRAOka4FIyUjBN62.xmZsZgwoayGMZgE1+oeeVh2BWF1eznwCAVA+smjIpXkkmMcV4yXPCoVhxaTdI7cC+tNe2hlmTzekGXFE9eXQvKxyqhmWq6L9W4qVlLacxxat4jj9SAZu5MykSYOHO0a8FsPwTVmd+FGG6hPWpS3jFOuLuCdDhe8brdIJIn4SOo2mLTMPMP2WIGxNa0e1e.K2zL+SrWBOor9aLyBCOP6NT6aZryvt5E4eOxLpxEpUOqOeX5t5JzH+lNa9l7UE9cpyeoEjDyEjjWGHIveI0pUdP+j89fpAnjQiYIJaeQBnex3DqPYGy0Nio+3KPIWfRdtfRfeoQrjZhEy042ROvuTsh3oO.w.Qaxu+LLyfyLfECNP8T3hdeBHVWF6ViJrEq7ooCg5ZeVRl8FShWHxgE7N8MlImaklULI0RQjACOjST2nI83A11Bg7eK++ca9hIMaOxWqluTryPrKP.Js5LBD.XUAnl2PoKwMZjNgMpeO0f9CY8FM5o1JiM6Jj3Xux2joFQwkZ2M14ursYS80r23o+LlDgs8.qVlDzrj4YWWY2v0vXwhaidhGjv6FQ+g.xzNy4DX9eJl6714dYLg4D568pxdB8ddT2mQnEFY6V4FHz.ws.ggnwUZAJCQr3AIAgV3OUoIDTZBQzMHauIdekVPRoEjQ2fhPKT8gPQoITQ2flfzTkVPSoEzQ2fgh7ZklvPoILQ2fs8lnekVvRoErQ2fivZZW2J2.gVvEcCdJnFUZBOklvWdCDVz0uBtAkEcQq4nfLML9IfDvTLxDkGggUFjn8LD+PP.3XTkVfBtAOB2fS.2XbkVfBtAOB2fqn.9UoInfavivM3DvMdekVfBtAOB2fan.9UoInfavivM3DvM5UoEnfavivM3NJfeUZBJ.G7HfCNAfi9UZAJ3F7HbCBqHFv5FSe67OZ8ffhxX9tUtABMPDrgfjFYUZBJvFhHXCAgAogUZARiRwCSRJXeUZBJ3FhHbCAAbiQUZAJvFhHXCAAXiwUZAJvFhHXCggB1WklfBrgHB1PRQZJdAAk4gnoAByBCiYOkIgn4.ME4nX9SYJHZFfvDvnX1SY3OZzm.l83X1SAxNBw1QQ7Il+TvqifqIfV+9X1SArtDqlBJTrJdD.gJgfn.T+93wFJ.0Q3zTfo6EydBfzQXzTfn6Uo6SYzIZ3g.tP+X1S.VHBclB37f3oVBvBQPyTPlG7mh4OAXgHfYJ3xCiYOAXgHPYgkBpVL+IfKHJwEDDvEFEydBvBhRXAAAXgwwrm.rfnDVfjpCw3BDDMKkLkLJXlwbm.tfrDWPR.W38wrm.tfrDWPJn.qEyeB3BxRbAIgQ+dwrmxfeznuhBrVL+I.LHKAFjD.F5GydB3BxRbAIAbgAhtwz2N6KwEjVJvZw7m.tfrDWPR.WXXL6IfKHKwEjdJqbi4OAfAYIv.EE9iwEHH5TJ4nn3G4n9th.rfpDVPQwIxwrm.rfpDVPQxCxw7m.rfpDVPQw8wwrm.rfpDVPQx2ww7mxbazjKEGGGydBvBpRXAEIuFGyeB3BpRbAEEWFGydBvBpRXAEE+EK6FSe6ruDVPQxYww7m.rfpDVfhU5wvBDlaKmZ0TbSbTeWS.VPWBKnI4i3X9S.WPWhKno3f3X1S.VPWBKno3c3X1S.VPWBKnI4Z3X9S.VPWBKno3W3X1SQzIR1gjSgi4OAXAcIrflhGgiYOAXAcIrflj6fi4OAbAcItflhufiYOAXAcIr.IWqEiKPXvubr2PwOvptwz2N2KwELjbBbL+IfKXJwELT78RL6IfKXJwELjrgKl+D.FLk.CFJpBFydB3BlRbACksThYOAbASItfgjnYL+oHZFIaR.W38wrm.tfoDWv3n.qEyeB3BlRbACAbgdwrm.tfoDWfxfSLr.gAmxwFKo7cIpyaIfKXKwErTBKdL6I.KXKgErThdltaL8sy9RXAKofQDyeBvB1RXAKkfQDydBvB1RXAKofQDyeB3B1RbAKkfQDydBvB1RXAKkfQDydJR9Qh9jBFQL+I.KXKgErTBFQL6I.KXKgEHApEiKPn2W14cjhFQTu2Q.WvUhK3nDMhX1S.WvUhK3HEMhX9S.XvUBL3nDMhX1S.WvUhK3nDMBS2X5am8k3BNRQiHl+DvEbk3BNJQiHl8DvEbk3BNRQiHl+D.Fbk.CNJQiHl8TVYEszhRzHhYOAbAWIt.EkQhgEHv8HlSJXDQcdOAXAeIrfmRvHhYOAXAeIrfmTvHh4OAXAeIrfmRvHhYOAXAeIrfmTvHh4OAbAeItfmRvHhYOAXAeIrfmRvHhRjTOAXAeIrfmTvHh4OAXAeIrfmRvHhYOAXAeIrfmTvHh4OkUt9Gyoc1tz7+E+7NSZM3x6wIroVmToBkGh4ayQcV6mLctmuig7pkRwwkJwwUCwwE6vworxwojxwwt93PSebHrNNDUG6K6i8U8wN05XeVcrwsGa75wZ4drRrGua2w6lgpmCT4ZfRbaThYiRQSTNXhRZMTRogR6LTdkgxbLTlggx8KTxcgReKT9Ygx.KTFVgxgJTRRgxTITlHgx0HTxDgRWHT5.gR3GTF8fxYGTR4fR6FTZ0fRbFTlwfx8ETtsfxdET5ofR.ETFlfxxCTVbfxSCThXfR0BTpTfRVBT1Pfx2AT9LfxXATJIfR5.TVEfxa.TdAfh7OJz9nf2iBNOJB4nPfiBxMJJ1n3TihCMJRynPIiBVLJXvnv8hhmKJhsnHxhh4JJnpnvlhhKJJxmnHahBuHJ9gnHDhh.HJFenf3gBSGJNbnHsghjFJVYnfggB2EJbVn.VghHEJlSnXJghZDJrPnPyfh8BJ5JnnmfhOBJ.HnPbfBgAJHEnnPfhy.JPBnPEfBE.xY+Hu4i7WOxe7HOtiboNxu1H+Vi7LMx0yHmKi7dLx+vH++h7vKxEtHmzhbBKxMqH+nh7TJxUnHmchblIxckH+Qh7IHxmeHu5gbaGxwbHGugbsFx2YHuigb+ExAWHGXgbQExGTHuLg7hDxOQHGAgb0CxWNHGpfbXBxkHHedf7pAxqEH+Rfb7.x0BHWGfbN.x5ej88HC3QlniLAGYjMxJZjcxH6fwkXMtFpwEIMtJnwk4LtLlw0oLtPjwUZLtRhwkJLtVfwE6KtXdwUqKtbbw0aKtfZwULKthXwkjJtlSwEUJtnQwUEJtrOw00ItvMwUlItxKwkVIt1IwEGIt3GwU2Ht7Ew0mHt9CwEXHtBBw0vGtH8vUgGtJ6vkQGtN4vEBGtP2vUxFtT0v0hFtXyvUSFtZwPGJ7+sMYq1Tbh5z7YuwK0wA692IAuQOOXEoJCy44VgzHEt5OOXcly5T2omu23D0f9pj9b13Do235KM86aj+N5k6wy5AKauoSaVXW70eLz8UKWHExy5.cTMM2jnxUgyST+0IWKLbal45rbU1Ss6ZgwkaqdNh816rQac9lwgWmJ+96w5GWs82WOUse.Rs71am2x9Wm+q4Yhmua6AddLTKdTTKoS8Y.Ywkrzv6EV9gCt7ivqbxZvqjLaJn.IiYzO79PsgipZ+nv4FIneW+gvEy.6PUOuPKFnt7Vp5Dsj3EqkjjZI9W+e9PSGW3wqhptJo5pfqZ8M1kpYbA8yLtvNIUp3BA.uy8vJW6R0dlQZEL6odkDH3pTl6PPfKV6J3gHCqYbmW.5pTb5ye5EuNV3kV8MYWmjYbtDsPJcSLWqrJ2Sh5FwKd2cCUD+R8NmPpEdki6bVG2BemBrUznrVlUYDRv36GkPVCBRC12AZPNxblxQzEiH8Ns9zmKnRIXYtzY7FgyypCYWacmIx9v9JAfrOZXhmMreRuACDhg8jiFHEO0uQyOV13mN7tk5Y6S0IScRgHvD7saJfSe3SpCeRe3SlHgs+eKtOCFRZTZy9G6y111kgq0ZJkRlpTJtV7vaqk2bmssrWvy1V2qVW9rSN5Uy6.HNreqioYZoky14RGJPpOFww+P3zmmy2nquTtNx+hungrkoqyWL8mWt3mWkutRNFV2KY150rzmBp4w.QboSZOAxqyKSkLsCLryX2evi+khCgV.Q1ps9CudqaH0Csr9IJyvgI8cfMhtdftdCFyM79CdxUt7YSZ+3g4e24HFRudmNVrKZozjIaua671dkOYN22WhOlET6zFKossV1cTASXYWwYwvurJ696a8cca8q3roFtzEduey7m5sBuCr3SXB1AU8Th2.lyITJvftVcdrzJAE1ESyRrVYdx0ZIejJSAp9ndpcdL58haXE2Nsq+cx0iVnTyJjpKPNHeTt1XzmuOaQy6zXdzQjqx6ZbDNXi6v7XeUN11Qv02h.78v8zt5dGnrdE9Xov1avleZslCanUazbLbQp.VTxLlnn4XRULX+w1CwGanCVN56kzSqcIFe+AZ2P1PkPelZ68LpZz2uc9lY2O+KMK0VSn0.Ck+3xUITgSeJcqx9Wizz8qRwqX7kaxJdc.SUuqIYyyI+3sYU1h0yI2.hSYlrvBlI6YdCy.5qoq0rDtyHS4Ltj6jkwhNQv4ofHpD1Kgw4VdixpvdDf0xfRgI9ghgI5wNuajO7JKUdtacrSv3OT6cb45ag82q4cE1k2G8WtzTf4eXSimaKOeM8mO7vleMBgyKbt9kqWt9xc8CUUz5hJFWt9Z1EBUBwHx.gisHohEGWUw7pFix8OFX7MKWcWyVvIujIvDhJDOU4sLtwyLVoq9T9jyk1Tlyq8fUZGL+B9KAK27kuwd+V3nf1cTN+pmf+7MOWfo40B0q6PgtO+ndD2whs2kr+ss651bV24DqdUph6XFljIrRUs9fn3XpvwJckVwZ.apRA2k0zl+GJccsQGbcsQwm9D4558CPuHQKZeaweAaKwKbjXqtCTEIv5W+hWHTmnd4Z4+OKm076Wdi9xdWOc6coR0JgSYpFlWuKUv4Dd0DeYuqWl8tLWj4eV0WCj0Uok6ecQf+as.u8M9qIbzqy9ieEgWSVCR9rHi8M3jHSoMoLEW5pDlItPvSMRiPxZIbnCEgbMumoWReigmvD85ORqGXEiG+TmNwGOzlp0.tfO7udtmCa287cxjcbk4deddKo.vKUFZxej4ZVsBFRXvLjLKBAHBrKthtZydLmQq3VkamXwdLVkK0BeIyJZ6bqiK7F.l0nR5YTlD8fQRPbQ3ENyyMLK6qJEoJmx+g7aaMcnNqDLjXLtOisHMfZgvREmfeH0rKrmCl97LESu2LvSO8MxNZbhxqTItwCDICcL2nQLkTN3MRlt9ZKBLuLYc6qqm55zA4jUHlnwEbV1KMH6ayC9.M2CK54Fi2K3tZbziQAHC6+ohs+4pT.mvA6IHd0p3LmhJuoLMa2+XUZl1wLeyUB1dFmWGsm8qe8BAIdCnzGWeTsGx81Toya0ZgxyDsrEgF1YHQMxJS5KE9DSemlYXlQlwUROb1WiK+186mr7x36qArPD8yVbadSREb2dgBtVn0VosFohnzgFF8Wd6xsq6TTsgqad5U7lZ5Ux.c+jdsl0hIxZInjup+.dHw+GlLXzX2vwCTbgj+1clcvx6tedNrRdS1puPZ1U9rqiWQ4fLOeBgzLLJuYotaSq0w5Wu.lMT9eBFGTlTD41wGE9gw48f8j9AINvTxDOnVK2vjRkh8rW6xuH0mZM6Y8MpebPHqIwlepcc3NRX8piBlv9sVqSEu22lEUV0ab+EUOIyVzlKdpdRn2z69fhslx69aGeZoSpAn7FrKFgr6uc7gtdKOpj88k3awovegqKXVqU6rQVDCecpWB5KpDGNSndcdV7yd8dV7ejGyZ+XZvpet2Y8w5K1mVYMo4bOWOTC7iRTis5j9pwrDMHg02xki5w6+bezMbNGqGHYxSHy8nDVL+AKPBI7W6QR.PS87TPkaFyDGKAojmp.4duk0VsE+sKXB7WrPG7erMuyesvHlFkuqIPYYyAQ3vFwsMqdyr4yaoFxAhVt.ULsGOnDdS5rI+yaZR+.1mURyXyP3OZyHPgsSDgAuJELJP30fEDGerkojxTulo.hz6Ji1PjoD0EYJuzSNC7jC3CSTF6vjdVgHgMdf1Xzg5i+QbHlMkMAv3ZpT8JFgtJZ5Idvc+rQjNuqVt89lm6cuUl6+GKFjMeRQch2Ia88fU.cVER10SICX8vLpEeLaJr5TPUrc4f1mKpOZNO8n7NKQJ7oFMr0iR2Zku8Vcp2+VYpuImEHc5TsxxzNNSuOPg6mp8bQJnvfvIDOnFzNki7Xkiz1GgV3uQmvcOwmlsbsBG2OlqlS3FgV8HNzvf4KXi49iR78T8RzFubDuuWv07yci4r4WmOcYidCI0q7Lt2DdP3NPjR.Zdx1o4ICPJDJ3etZWEjbg3KDeg3KDeg3+XQbvg161J4muKK9P5Kri81U4ugK.7viFnyvho+7cKml+XcV+WWhoDN2a9Vzb+7lWhFr8Ss7cBMc9dvxlUyxl2rNbr2JJs+21EolE214+tS1cAGUzY4MctKOu36VrD57cxVLsycY+yvWrNLDr4i4e4eG9+KWL+Kc1+n24W9X9hN2uJe857omvH.qRjZrfA7GarOX29Nk9UVN9ksQHZgjUK8spR+72JBLkl2ChAfPy8KWOK3lqfXSNL99kNymsH+DR.BqMUXrRuFfv0UOdzXZQpzx0NA6fCe.AhPpHXAa7qXoRBPcpObNqAX9rVOtzdiJSHdqHSzqyuLa9zNSVdWnq0I696yyVs9e6jBAg2uJ1P5XHkhpGRd1vgrp25Ek4Sb37X0wScRoeu6f9Ci.f7sGnPXwemcSlmJuxCYb7CY8wgIdsPlBvBRgxd3bvuHARjN...1OnzuQgoekvFNIrXvVJ+NzqegP0LqHKn.5WkE9TwaHdu0kxfUFkmsjEKETv9pbXkjiw16az+0xk2Uj4SZlv40B.3jK7dqpZNd7ScCCBgXRaBYUa3D.yE9fK3RFYH+6C9xwTbI7U5vWoC2iL7ZCn3+B+nN7IcX.RFtnB7PE9AWfkpPCnJ9TAeKZy.IVe2hrmB9gvmTAtKCDWbVjU3GIaAcgOIKHt3dCjXCDaCeRGXpMzCJNt5KR8LanaXB2gIbGl.+Jx9TQ3GzE+PQCEtWQweMv.a3uZJt2.6KJIYQwmbcAUD++Cv1EvXH
--end-wire-patch--
--end-wire-patch--
JonasVorwerk
Re: Instances
Hi Tijn,
Very interesting to se your approach and a few new objects which I didn't know like the filter note, great stuff.
Also the dynamic amount of notes is a great add-on!
What I'm trying to do is to create a ripple effect when touching a note (also several times), so the movements should continue even if the note is already off.
I'll continue later tonight, thanks again!
