Animating slide-in-and-out of elements on clip triggering
badbwoy89
Post by badbwoy89 »
I have a background for speakers' presentations, and I need to animate the appearing elements like session titles and sponsor logos so that they slide in from one side and slide out to the same side when I trigger a new clip. In other words, suppose there's a title; I trigger a scene with a presentation, and first the title rolls out to the left, then a screen with the presentation descends from above.
My first idea was to create this as a transparent video in After Effects, placing the elements on a canvas of the original resolution, but I suspect this isn't entirely optimal and there might be better ways.
Next thing is that organisators asked me if i could do a little animation - when presentation slides in from above - it is placed inside a stylised tv and they want it to display white noise or oldschool screen pattern (they haven't decided yet). So my thought was 3 layer system - top layer is tv itself, next comes white noise/pattern video and below that comes screen capture of presentation (of course after i'll figure out initial transition). Question is pretty much the same - is it reliable, or are there better ways to do this?
Tnx
Re: Animating slide-in-and-out of elements on clip triggering
Layer transitions has Push blends https://resolume.com/support/en/layers#layer-transition the would push in the same direction, on "fade" in and out.
How do you slide in the presentation?
If manually with a midi controller fader, then you could play the tv in a group (Arena only) above the content layer, and have the controller fader mapped to the y position of the group, and optionally a static source's opacity in the same group
With Wire you can create custom transitions/blends like this. Cloning the Video Bumper could give a nice base.
